Range Outlet. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2011, 11:46 AM   #1
Rewards Points: 154
Range outlet.
How high should a 240 range outlet be off the floor?
Thanks.
Abs777 is offline   Reply With Quote
Old 03-03-2011, 12:08 PM   #2
Rewards Points: 320
There is usually a space at the back of the range that allows the unit to be pushed tight against the wall. I try to mount the outlet where it will fall into this space.
teamo is offline   Reply With Quote
Old 03-03-2011, 02:50 PM   #3
Licensed electrician
Rewards Points: 1,506
Appliance makers put the allowable area in different locations. Check the installation instructions.
Old 03-03-2011, 03:00 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,950
Typically it should be right at the floor, but listen to Jim to be sure.
Old 03-04-2011, 04:08 AM   #5
Electrical Contractor
kbsparky's Avatar
Close to the floor, or on it, as can be the case with surface mounted receptacles. The space behind the bottom drawer on many ranges usually accommodates such arrangements.
The Code recognizes the range outlet in such a location as a disconnecting means IF you can remove the drawer, AND unplug the appliance without moving the range itself.
-KB
Electric range in dryer outlet Greenlevel Electrical 5 02-03-2011 05:20 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Replace Range Outlet Suncrest79 Electrical 22 04-14-2009 11:32 PM
Dryer outlet vs. Range outlet cindakay Electrical 24 04-13-2009 06:01 PM
changing a range outlet or plug marty7 Electrical 9 12-17-2007 10:11 PM
