Range & Junction Box Distance - Electrical - DIY Chatroom Home Improvement Forum
Old 05-10-2008, 06:58 AM   #1
I have a junction box on the wall behind a Range/Cook Top that I am going to use to put outlets on each side of the range. Can I run conduit on the wall behind the range, and if so, is there a minimum height off the cooking surface that I need to maintain?
G3Aloha is offline   Reply With Quote
Old 05-10-2008, 12:13 PM   #2
Rewards Points: 204
If you are running the conduit behind the range you will be below cook top level.
Junction Question? fw2007 Electrical 10 03-31-2008 11:03 AM
3 prong range? laduehelp Electrical 39 03-11-2008 01:33 PM
gas range swap kenny11876 Appliances 2 02-20-2008 08:31 PM
direct wire a range j1mw3b Electrical 7 02-16-2008 02:40 PM
Replacing Stove Top with Range the.vicster Electrical 3 02-23-2006 05:12 PM
