Range Hood Wiring Question, Help!! - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2009, 07:55 PM   #1
Unhappy
Range hood wiring question, help!!
Okay, so i took out my grandparents old range hood over the stove. It wasn't plugged in and hadn't been used in my life time. I threw the whole thing out without looking at it. I went online and purchased a Broan stainless steel ductless range hood. I open the box and look for a cord to plug into my outlet but instead i find a black wire and a white wire with exposed tips... How in simple terms do i get this thing attached to my three pronged, standard USA outlet in my apartment. Any help would be appreciated =) Thank you!!!!!
nyc_apt_dweller is offline   Reply With Quote
Old 03-05-2009, 08:01 PM   #2
biggles's Avatar
go over to HD on W23rd and get a yellow male adapter plug that you can slide the 3 raw wires into...if the cord out of the new hood is long enough.........any hardware store in your area carries them http://www.grainger.com/Grainger/wwg...=29&submit.y=6
Old 03-05-2009, 08:15 PM   #3
Thank you .. and thank you for the link
Old 03-05-2009, 09:26 PM   #4
Terrible advice.
Just get an appliance pigtail and a 1/2" connector and wire nuts. You don't make your own cords when the item you need is readily available.
The 3 to 6 foot pigtail has the plug already on it.
220/221 is offline   Reply With Quote
Old 03-05-2009, 09:34 PM   #5
Rewards Points: 506
Send a message via AIM to theatretch85
Whoa! Talk about code violations! What Biggles is proposing is very bad advice! The wires on the range hood are not meant to leave the housing of the range hood, the sharp metal edge would likely cut into the wires. Also the wires will almost certainly not be long enough to reach the outlet, most likely resulting in an un-safe junction inside the cabinet.
Do as 220/221 suggested or hardwire the range hood and remove the outlet completely.
theatretch85 is offline   Reply With Quote
Tags
range hood wiring
range hood through the wall - - -stud in the way pacifier1er Building & Construction 30 05-21-2013 10:23 AM
suggestions on contructing a range hood steve1234 Carpentry 15 08-30-2010 11:35 PM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-16-2008 12:13 AM
Same Circuit: Range Hood, DW, and GD? atty_toconnor Electrical 4 04-08-2008 05:43 PM
Can I Wire a range hood to an exhisting outlet? skellies Electrical 2 05-09-2006 05:06 PM
