Old 12-02-2012, 10:25 PM   #1
range hood wiring question
i wanna thank all you guys for the help on other topics
i will be installing a new range hood soon
the outlet is just by the back of the gas stove clock
can i tap the hood wiring into this outlet from behind the wall?
i have 12/2 wire and know how to wire from point A to B
but i have never ran wire behind a wall before
thanks,john
BTW the wall is 1920 plaster
fix what? is offline   Reply With Quote
Old 12-02-2012, 10:35 PM   #2
Lic Electrical Inspector
electures's Avatar
Yes. As long as the receptacle is not on a SABC. If it is #14 you should be ok.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 12-02-2012, 10:39 PM   #3
sorry but what is a SABC ?
Old 12-03-2012, 07:33 AM   #4
SABC stands for Small Appliance Branch Circuit
Bruntson is offline   Reply With Quote
The Following User Says Thank You to Bruntson For This Useful Post:
electures (12-03-2012)
Old 12-03-2012, 09:08 AM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
If you have enough breaker space, or can put in a tandem breaker, pull a new circuit for it. You never know that later on, a Microwave over the range may take its place.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 12-03-2012, 03:15 PM   #6
Julius793's Avatar
If you will hard wire it its fine if your going to add a receptacle and plug it in it must be a dedicated circuit
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
yet another 3 wire range hookup question - grounding receptacle plate/box? rkg Electrical 7 04-03-2012 02:02 AM
Range Hood Venting Considerations RyanPaq HVAC 0 11-12-2010 03:52 PM
Range hood wiring question, help!! nyc_apt_dweller Electrical 4 03-05-2009 09:34 PM
Range hood, hardwire or receptacle? DIYGST Electrical 11 01-10-2009 07:55 AM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-16-2008 12:13 AM
