Old 08-03-2012, 10:03 PM   #1
Range hood Wiring
I am wanting to install a plan range hood vent and light, I was wondering what size wiring I should use 14/2 or 12/2 and also if this should be wired separate breaker or could it be with other circuits in the kitchen. Thanks in advance for any help or input.
POWERSTROKE84 is offline   Reply With Quote
Old 08-03-2012, 10:10 PM   #2
"So I Re-Wired It"
MisterZ's Avatar
Range hood Wiring
14/2 is OK, and does not require a dedicated circuit.
If in the future you wish to use this wiring for a Microwave Hood, then you'd need a dedicated line on 12/2 20amp breaker.
just thought i would throw that out there
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Old 08-03-2012, 10:16 PM   #3
Range hood Wiring
would be ok to run 12/2 20 amp breaker now and hook up the hood range vent to that?
Old 08-03-2012, 10:23 PM   #4
"So I Re-Wired It"
MisterZ's Avatar
Range hood Wiring
a new 20amp dedicated line?? yah. just check the Amp rating for your hood.
they make both 15 and 20 amp range hoods. if yours is 15amps you should use a 15amp breaker.
either way, swapping a breaker out is easier than running new wire
Old 08-03-2012, 10:28 PM   #5
Range hood Wiring
Thanks man very powerful info.
Old 08-03-2012, 10:30 PM   #6
Range hood Wiring
is it ok to use a 15amp breaker with 12/2 wire. if the amp rating is less 20
Old 08-03-2012, 11:12 PM   #7
E2 Electrician
stickboy1375's Avatar
Range hood Wiring
Yes, it is.
stickboy1375 is online now   Reply With Quote
Old 08-03-2012, 11:42 PM   #8
Electrical Contractor
Range hood Wiring
If you run the 12, why bother with a 15 amp breaker?
If you replace the hood with a microwave in the future, you would have to go back in and change the breaker.
The breaker is there to protect the wire only.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 08-03-2012, 11:45 PM   #9
E2 Electrician
Range hood Wiring
My thoughts were the hood required a 15 amp breaker maximum...
Range Hood Ducting go Down? jerryk1234 Kitchen & Bath Remodeling 15 09-22-2011 11:10 PM
Custom Range Hood Help, Please. pretzels HVAC 11 09-09-2011 04:54 PM
Range Hood Venting Considerations RyanPaq HVAC 0 11-12-2010 03:52 PM
Range Hood install opinion Manshri Appliances 5 01-01-2010 01:04 PM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-16-2008 12:13 AM
