Range Hood Wiring - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-03-2011, 01:00 PM   #16
I=E/R
a7ecorsair's Avatar
Ok, I went back through everything in the thread. Is the transformer connected to the red wire? If so, remove the connection and connect your range hood at that point. Be sure to connect the ground wire from your romex to the box.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
sirsparksalot (04-03-2011)
Old 04-03-2011, 01:01 PM   #17
Rewards Points: 512
I apologize, I guess my drawings are inaccurate. Please look at the actual pictures.
In the light box: the Romex goes to my Hood. I have it tapped with the black going up to the switch box, and pigtailed to the light. There's a Red coming from the conduit on the left (which goes back to the panel) running through the conduit to the switch box.
Old 04-03-2011, 01:02 PM   #18
Rewards Points: 512
No, the red wire is uncut and goes straight through.
Old 04-03-2011, 01:04 PM   #19
Rewards Points: 512
I'm going to open everything back up and make sure that the info I'm giving is correct.
Please stay with me.
Old 04-03-2011, 01:13 PM   #20
Rewards Points: 512
well, ONCE AGAIN, I'm wrong!. a7, the red wire is spliced in the light box to the transformer, so I should not have a problem with this. I'll splice my hood lead to the red in the light.
The transformer, I believe, is an unworking door bell component.
Old 04-03-2011, 02:20 PM   #21
Rewards Points: 512
Well, I got it done, EXCEPT ONE THING... one of the screw connectors on the ceramic light holder broke off, and I have to replace it - no basement light for now!! But the hood now works w/o the basement light switch being on, and that's a good thing.
I did redo the panel, per a7's advice: black and red wires spliced together and a pigtail to the breaker (in addition to the other circuits, this breaker runs the Dishwasher, BTW).
Here's a pic of the finished light box; it is now covered with a cover plate until I can get a new fixture.
Range Wiring Question - Not Usual Question RWessner Electrical 5 12-04-2010 06:44 PM
Range hood installation problem Lucas718 Appliances 4 08-16-2010 01:28 PM
Installing a range hood NewHandyman Electrical 1 08-10-2009 09:42 AM
Help needed with finding the wires to install a range hood triginpgh Electrical 6 01-10-2009 02:09 PM
Cabinet Crown Molding and Hood Range? gate1way2 Carpentry 3 10-15-2008 11:13 PM
