Range Hood On Microwave Circuit - Legal? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-10-2012, 09:15 AM   #16
Thadius856's Avatar
Rewards Points: 504
Thanks everybody!
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 08-10-2012, 05:04 PM   #17
"So I Re-Wired It"
MisterZ's Avatar
Originally Posted by frenchelectrican View Post
I put a underline part but I just want to double check with ya about the shared circuit which part are you refering to this ??
Merci.
Marc
I didnt explain well. Was referring to same NEC as Stickboy, adding exception #2.
"Exceptions in 210.52(B)(2) allow clock receptacles and receptacles that are installed to plug in the cords of gas-fired ranges, ovens, or counter-mounted cooking units in order to power up their timers and ignition systems"
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
The Following User Says Thank You to MisterZ For This Useful Post:
frenchelectrican (08-10-2012)
Old 08-10-2012, 05:05 PM   #18
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I knew what you meant.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
frenchelectrican (08-10-2012), MisterZ (08-10-2012)
Old 08-10-2012, 11:25 PM   #19
" Euro " electrician
frenchelectrican's Avatar
Merci for clearing that one up I almost forgot about the exception #2 but the wiring metholds still the same as far I done for a while.
Side note in France we don't have any exceptions on kitchen circuits on countertop but luminarie ( hardwired ) they do have one for it.
Merci,
Marc
Hard wiring range hood Neilolo Electrical 3 03-04-2012 02:57 PM
Problems with range hood installation. darsunt Remodeling 9 01-06-2012 04:59 PM
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 06:19 AM
Range Hood Wiring sirsparksalot Electrical 20 04-03-2011 02:20 PM
Island Range Hood? fromwithin Appliances 0 11-25-2009 10:45 PM
