Range Hood On Microwave Circuit - Legal? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2012, 08:16 PM   #1
Thadius856's Avatar
Rewards Points: 504
Range Hood on Microwave Circuit - Legal?
Just pulled six 20A 12-2 home runs for the kitchen remod. Want to make sure I pulled these correctly before I consider the rough-in complete. Pulled two countertop small appliance, one dishwasher/garbage disposal, one refrigerator, one lighting.
The sixth serves a single counter-top receptacle where I plan to plug in my countertop microwave (1200W). I ran the gas stove pilot light receptacle and range hood light/fan power off this circuit. I figured this was logical since a micro/hood combo gets its own circuit.
Is this legal, or do I need to fix this before I continue? Still have plenty of wire hanging out of the boxes if I need to make changes.
Check out my on-going Project Thread!
Current Project: Whole House Data Wiring
Back Burner: Drywall Patching
Planning: Kitchen Reno
Thadius856 is offline   Reply With Quote
Old 08-09-2012, 09:07 PM   #2
"So I Re-Wired It"
MisterZ's Avatar
Micro Hood must have dedicated circuit. Countertop one i dont think its "required"
1200 watt is a decent size, if its no trouble to give it a separate circuit, why not do it?
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
The Following User Says Thank You to MisterZ For This Useful Post:
Thadius856 (08-10-2012)
Old 08-09-2012, 09:18 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I would put it on a separate 20A circuit...the range hood that is. It is probably going to be overkill right now, but its going to come in real handy when you decide to install an over the range micro.
The Following User Says Thank You to k_buz For This Useful Post:
Old 08-09-2012, 09:19 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You cant have the hood on this circuit, put the hood on the lighting circuit, the stove is legit.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 08-09-2012, 09:20 PM   #5
E2 Electrician
Why cant we just answer the code question?
No, the third small appliance circuit you pulled to the countertop cannot serve the hood unit....
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
MisterZ (08-09-2012), Thadius856 (08-10-2012)
Old 08-09-2012, 09:26 PM   #6
"So I Re-Wired It"
MisterZ's Avatar
re-read the post. misunderstood. thought he had a MicroHood on dedicated, and also a Counter Microwave on another countertop circuit.
Old 08-09-2012, 09:32 PM   #7
k_buz's Avatar
Could you point to a code reference on that?
Old 08-09-2012, 09:38 PM   #8
E2 Electrician
Right back at you, tell me where it is allowed....
But since you asked, 210.52 (B)(2) No Other outlets. The two or MORE small-appliance branch circuits shall have no other outlets...
Old 08-09-2012, 09:43 PM   #9
E2 Electrician
Two small appliance circuits IS the minimum, but you can have as many as you want, but they still ALL fall under 210.52 (B)
Old 08-09-2012, 09:45 PM   #10
E2 Electrician
I agree with this statement as well.
Old 08-09-2012, 10:05 PM   #11
k_buz's Avatar
One word missed in a different code messed my logic up. I agree with your assessment.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
stickboy1375 (08-09-2012), Thadius856 (08-10-2012)
Old 08-09-2012, 11:31 PM   #12
Thadius856's Avatar
Rewards Points: 504
Read all this twice and not sure I understand fully. I think the concensus is:
Move gas range to one of the small appliance circuits.
Move range hood to lighting circuit.
Now have 3 small appliance circuits, the 3rd one to the single countertop receptacle for the plug in countertop microwave.
If I ever decide to change to micro hood some day down the road, pull 3rd small appliance back up the wall cavity, remove hood from lighting circuit, and drop the spare circuit back down to dedicate to microhood.
Is this correct?
Old 08-10-2012, 12:27 AM   #13
"So I Re-Wired It"
MisterZ's Avatar
Minimum 2 small appliance outlets in kitchen. These outlets shall not have any other outlets. (Dedicated)
Just run a dedicated circuit for the countertop microwave.
Personally i would run another dedicated outlet for the range hood. I dont believe it is considered a small appliance.
Although it may not be required, to do it now would save time and money later.
The gas range is not considered a small appliance, as it only powers the clock.
It can be either a 15 or 20 amp shared circuit.
Old 08-10-2012, 12:35 AM   #14
" Euro " electrician
frenchelectrican's Avatar
I put a underline part but I just want to double check with ya about the shared circuit which part are you refering to this ??
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 08-10-2012, 07:03 AM   #15
E2 Electrician
Is this correct?
For the most part, or you could new a new 20 amp line now for the hood, it's up to you.
Hard wiring range hood Neilolo Electrical 3 03-04-2012 03:57 PM
Problems with range hood installation. darsunt Remodeling 9 01-06-2012 05:59 PM
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 07:19 AM
Range Hood Wiring sirsparksalot Electrical 20 04-03-2011 03:20 PM
Island Range Hood? fromwithin Appliances 0 11-25-2009 11:45 PM
