Old 03-13-2012, 11:15 AM   #1
Range hood- 15 or 20 apm?
Our new range hood states is should be a dedicated 15 amp circuit. Is okay to put it on a 20 amp or would that violate code?
kidsncats is offline   Reply With Quote
Old 03-13-2012, 11:20 AM   #2
J. V.'s Avatar
It's fine. I am guessing 15 amp dedicated is the minimum. Does it say minimum or maximum or does it not say? If it does not say, use the 20 amp circuit. You can always put a 15 amp breaker in the spot where the 20 amp breaker sits now. It is okay to use a 15 amp breaker on #12 wire.
Old 03-13-2012, 11:23 AM   #3
The manufacturers specs dont specify min or max, just dedicated 15 amp. We are having our rough inspection Friday and weren't sure if the inspector would call us out on that.
Old 03-14-2012, 09:22 AM   #4
No inspector I've ever seen would do that. A circuit rated for more current than what you want to plug into it is hardly a code violation.
The Following User Says Thank You to md2lgyk For This Useful Post:
kidsncats (03-14-2012)
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 07:19 AM
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 08:00 PM
Alternative to range hood fan Richo HVAC 2 04-11-2010 03:43 PM
Island Range Hood? fromwithin Appliances 0 11-25-2009 11:45 PM
Installing a range hood NewHandyman Electrical 1 08-10-2009 10:42 AM
