Range/Dryer 3 Prong To 4 Prong Outlet Conv. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2012, 10:13 AM   #1
Range/Dryer 3 Prong to 4 Prong outlet conv.
I am new to this forum so bare with me.
There are several posts on converting a 3 prong outlet to a 4 prong outlet to meet the more up to date codes. Regrettably, my house id from the 80's and the builders were cheap you-know-whats and the 10/3 wire they ran to my dryer did not have a bare ground.
Here is my question; If I pull a bare ground from an adjacent outlet and use it for the ground post in the dryer outlet what would be the disadvantage of the idea?
To my thought process this would give me the proper 2 hot, 1 neutral and a ground that I need. The circuit would still be completed and the ground would still run to the box.
I appreciate any input... Thank you in advance.
Abbell is offline   Reply With Quote
Old 11-20-2012, 10:16 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 474
If you are not moving the dryer, then the installation is compliant the way it is.
Nothing needs to be changed.
jbfan is online now   Reply With Quote
Old 11-20-2012, 10:19 AM   #3
I have a new dryer that uses the ground peg (4 prong) and the existing outlet is 3 prong. I prefer not to switch the cord on the dryer mainly because I like the more reliable grounding from a 4 prong outlet.
Old 11-20-2012, 10:20 AM   #4
jbfan's Avatar
Rewards Points: 474
Then you are going to have to pull a new cable from the panel to get your ground wire you need.
You just can't pick a ground from any circuit.
Old 11-20-2012, 10:23 AM   #5
Licensed electrician
Rewards Points: 1,608
Hard to believe wiring from the 80's doesn't have a ground. Was this NM or SE cable?
Old 11-20-2012, 10:47 AM   #6
It looks like NM since I do not see a bare ground wire, just the 3 insulated wires. Black, White, and Red all wrapped in black.
Old 11-20-2012, 01:18 PM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'll bet there is a ground in there and it was simply cut off.
Old 11-20-2012, 06:17 PM   #8
jbfan's Avatar
Rewards Points: 474
Nope, they made 10/3 without ground back then to comply with having an insulated neutral/ground for dryers.
Old 11-20-2012, 06:22 PM   #9
k_buz's Avatar
They must not have used it much around here...never seen it.
Old 11-20-2012, 06:26 PM   #10
Nor have I.
Old 11-20-2012, 06:41 PM   #11
jbfan's Avatar
Rewards Points: 474
I have only seen it in a few houses around here, and they were all dryer circuits.
Old 11-20-2012, 09:46 PM   #12
I will take another look, but I do not believe there was a ground wire.
Old 11-21-2012, 03:19 AM   #13
kbsparky's Avatar
I have seen this type of wire, and yes, it was popular in the early 1980s.
You can run an external grounding conductor, but it has to go back to the panel, or tie into your grounding electrode system. It is not permissible to connect it to an adjacent circuit's ground wire. [see NEC 250.130(C)]
But if you are going to all that trouble, you could simply replace the 10/3 with a 10/3g cable.
But you should be aware that the Code does allow for 3-conductor outlets for dryers, with grounding thru the neutral conductor in existing installations. All you have to do is re-install the bonding jumper in your appliance, and use a 3-wire cord in your existing receptacle.
-KB
Old 11-21-2012, 08:18 AM   #14
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
My electric range receptacle is 3 wire 8/3 NM (BK-RD-WH) without a ground. House was built in 1988-89. I don't use it as I installed a gas range and installed a 120 volt receptacle next to it..
Coastal South Carolina
Old 11-21-2012, 01:51 PM   #15
Licensed Pro
I run into this type of cable a lot, in 14 or 12 ga for 3-way circuits, and in 10 or 8ga for dryer or range circuits.
To the OP: As long as the existing cable originates from the service panel, you can do as KB stated and reconnect the bonding jumper and use a three wire cord.
Tags
code violations , dryer outlet , outlet , range outlet , wiring problem
Help rewiring 220V 3-prong outlet to 4-prong grounded outlet madmaxwell Electrical 7 03-23-2012 06:37 AM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Bathroom GFCI Outlet trouble RyG1357 Electrical 3 08-20-2011 03:40 PM
220volt 3prong outlet swap to 4 prong rp1666 Electrical 4 08-20-2009 09:03 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
