Originally Posted by kgbishop
6/2 was the correct wire for 50 amp outlet it has two leads and a ground
just to be on the safe side we got a professional electrician to look it over he said everything was A ok.
Then if that is the case your range is
only 240 volt..which is very odd. I think what you probably have is a cook top not a range. If you were smart you would read the factory nameplate and present that information to us. I am assuming your professional did this in order to be sure your correct in assuming 240 volt.
My problem is I have never in my career seen a 60 amp cooktop. So would you mind posting the electrical specifications from that appliances nameplate ?
Maybe take a picture of it and post here.
And again if you do this install without permit and licensing and you screw it up, at someone elses expense, when they do the accident investigation you will be liabel along with the church leadership. Not trying to be the devils advocate but you need to use some common sense.
