Old 03-02-2010, 05:28 PM   #1
Radio Static From Florescent Lights
I have 8 fixtures on the ceiling of my shop. They are the digital type lights and all are grounded. When you have a radio on with out the lights on it comes in crystal clear. When you turn the lights on the radio instantly goes to static. This is also true for a vehicle. The radio is crystal clear outside or inside with lights off but when you pull it in the shop with lights on it instantly goes to static.
Would like to listen to the races on a Sunday in my shop but can't.
PLEASE HELP
Nayr is offline   Reply With Quote
Old 03-02-2010, 07:27 PM   #2
the radio wire or more specifically the speaker wire is picking up noise from the bulbs...fluorescent bulbs need high voltage that arcs across electrodes within the tube...this arcing is whats causing you the trouble...get shielded stranded speaker wire if they make it or any type of stranded shielded wire with the appropriate gauge and ground the outer shield and this should take care of it...arcing is the worst case of EMI (electro-magnetic interference)
joseph2293 is offline   Reply With Quote
Old 03-02-2010, 07:39 PM   #3
its definitely available check here:
http://www.iec-usa.com/Browse05/MWireAudio.html
but the size...i would maybe try something like 16 gauge or even 14 gauge stranded
More On This Topic
How to Write
How to Write "Crystal Clear" in Chinese Characters by eHow Culture & Society Editor
Learn how to write Chinese today! This free video covering "shui" (water words) teaches you how to write "crystal clear" in Chinese characters. Read More »
Remove radio bezel before disconnecting electronics. Learn about procedure for installing dashboard lights in a 1996 Ford Explorer in this free auto repair series from a master mechanic. Read More »
Buy pretreated wood to withstand weather related conditions for outdoor DIY (do-it-yourself) projects. Purchase lumber with tips from a home repairman in this free video on home improvements. Read More »
Designing your own workspace at home is not as difficult as you may think. Follow these quick ideas to get you started on your way to being more productive while working at home. Read More »
Since prehistoric times human beings have been drawn to the beauty and power of crystals. Crystals are thought by many to have the ability to balance our mental, spiritual, emotional and physical well being. If you are interested in these healing... Read More »
Outdoor lights (Soffit etc) DIY_JC Electrical 2 09-25-2009 12:45 PM
Florescent lights on a dimmer swtich McCool Electrical 3 08-15-2009 02:07 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
Finding underground electric wire for driveway lights. mitch21131 Electrical 7 11-02-2008 07:30 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
