Radiant Flooring - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 07:23 PM   #1
Radiant flooring
We are considering the Danfoss mats for our master bath. A friend of mine mentioned there might be a code requirement to have the mats start a certain distance from the vanities. Does anyone know where I would find this info? I tried to find online but got nowhere with the county website. Also, in your experience, how much does the heat spread from the perimeter of the mat? I have gotten varying accounts on the heat spread and it will impact mat sizing.
steel1 is offline   Reply With Quote
Old 01-25-2009, 07:29 PM   #2
Remodeling Contractor
Are you installing this under tile or what type of flooring? No electrical violations involved with placement near the vanities or toilet or shower. We usually cover the entire floor except under the toilet, vanity and shower unit. Heat transfer depends on the heat mass you are heating. Radiant heat will move to the nearest cold objects. Electrical code would not allow the thermostat be placed where it can be reached by someone in the shower.
Old 01-25-2009, 07:35 PM   #3
Radiant flooring-more details
Installation under tiles. Cement board floor, radiant cables, scratch coat 3/16" thinset, then tile. 240V cable, each mat section 2' wide.
Old 01-26-2009, 05:25 AM   #4
then my original post covers it. It is fine to be as close to the vanities. Actually best to heat the entire floor mass.
Old 01-27-2009, 07:39 PM   #5
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
Keep 6" from the wax ring of the toilet. You can't install a line voltage mat in or under the shower or tub. Install the mat so the perimeter cables are within 1/2 the distance between the runs in the mat itself from the vanity and walls. To clarify, if the wires in the mat itself are 3" from each other, then you should be 1-1/2" from the vanity. That way it will heat out equally from and within itself.
Don't heat under the vanity or any permanent fixtures. It's not only a waste of energy but you could trap the heat and dry out the wood of the vanity.
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
How to cut exhisting flooring in the doorway jjpar Flooring 8 10-26-2011 12:01 PM
Radiant flooring question tpagel Flooring 7 05-21-2008 02:41 PM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 02:17 PM
Radiant Heat Flooring As Only Heat Source? digthisbigcrux Building & Construction 2 03-10-2007 12:33 PM
