Radiant Electrical Heat (hookup And Conduit) - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2012, 01:26 AM   #1
Radiant electrical heat (hookup and conduit)
I'm installing a new electrical heat in the master bath remodel. My last contractor routed all the wires for me and now its my turn. Manufacturer specs say to route the power wires through conduit and the temp prob hammered. We didn't do this before (mainly because the wall is already finished. I'm curious if this is needed because I don't see an option post rough-in.
Secondly the power says that it requires a dedicated circuit. I'm positive we didn't do this before and its it necessary. My plans are to spline off of a very nearby power outlet. I have a 120v mat and a 120v thermostat. Is it okay to just spline and run to my new box then hook it up?
joebanks is offline   Reply With Quote
Old 11-20-2012, 07:37 AM   #2
Licensed electrician
Rewards Points: 1,234
The ones I have installed had an option to skip the conduit on old work installs where the wall is already finished.
Depending on whether the circuit powers other bathrooms you might be able to add the heat. Otherwise you will need a new circuit.
Old 11-28-2012, 07:00 PM   #3
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
If it's not too late, whether-or-not you can connect to to an existing circuit depends on the current it will draw along with whatever is already on that same circuit. Otherwise, it will trip the breaker.
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
