Raceway Recommendations? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-11-2013, 08:25 PM   #1
Raceway recommendations?
I'm thinking of getting Wiremold 2400 series raceway for my apartment. I just need about 12 feet with various fittings. You can't find steel raceway in retail stores except for this small kind and I'm not sure I trust the plastic kind to screw onto to a wall permanently. Does anyone have opinions on raceway or experience with the 2400 series? It's for part of a hallway where I don't mind it not being decorative.
(for two coaxial cables, each going to two bedrooms)
Dorado is offline   Reply With Quote
Old 05-12-2013, 12:45 AM   #2
JW
mm11's Avatar
Rewards Points: 596
I've used wiremold before- it's kind of a pain to cut, but functional. If you have a portaband or can borrow one to make the cuts, it makes it a lot easier.
mm11 is offline   Reply With Quote
Old 05-12-2013, 02:49 AM   #3
Rewards Points: 512
What would be the problem with it being plastic? The part which screws to the wall would be the aluminum. The plastic part just slides, or snaps over that. Use wall anchors.
Installation is the Reverse of Removal.
Old 05-12-2013, 06:54 AM   #4
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
I understand .. here they call the 2 different one 500 series and 700 series 700 being the larger of the two ...
Is the plastic stuff rated for 120v ?? i thought that was for low voltage or ethernet ??
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-12-2013, 11:24 AM   #5
Some of them have plastic bases. I only want it for low voltage but I really hate the plastic ones I've seen. The ones installed in my building are hard to close and most aren't closed properly. I'm trying to avoid ones with tape because I don't want the walls messed up if it's removed and I want something more secure. If it's painted over three or four times, I don't want it ruined. With aluminum or steel you can use a heat gun or scraper and pull harder. And I don't want fumes from burned plastic if there's a fire.
Old 05-12-2013, 11:46 AM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Look for a plastic raceway, you dont want to be wasting a lot of time or money if its just an apartment.
Old 05-12-2013, 11:48 AM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Stick...this is the guy who was looking for a rigid LB to complete his conduit run so his tenants could rewire their low volt.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (05-12-2013)
Old 05-12-2013, 12:11 PM   #8
I was looking for a C body for EMT so a future tenant that I sell the apartment to, as well as myself, would be able to hand fish cable from the C body through a closed section of soffit or else keep the cover on and use fish tape from the beginning of the EMT. I'll post pictures when I'm done.
Raceway fill on rooftop Jaxx Electrical 7 03-03-2013 04:04 PM
Meter to LC, is this a Raceway? Johnd85053 Electrical 9 02-08-2012 01:26 AM
Conductors in Raceway brookny Electrical 8 11-12-2011 01:38 PM
residential surface mount raceway toddmpa Electrical 3 02-14-2011 09:31 AM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 05:44 PM
