Raceway Fill On Rooftop - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 11:40 AM   #1
Rewards Points: 187
Raceway fill on rooftop
Hello!
Per my research I determined that a 3/4 raceway (EMT or IMC) would sized sufficiently to hold 4x 8 AWG THWN-2 wires (BK, RD, WT, GN).
Now, I am not 100% sure how the fact that this will be installed on a rooftop effects the fill calculation.
Could you help me in verifying if this will be ok? Could I possible even go with 1/2" raceway?
Jaxx is offline   Reply With Quote
Old 03-03-2013, 12:07 PM   #2
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
I would not use 1/2" it's better to go larger than small, #8 wires are not easy to work with.
RWolff is offline   Reply With Quote
Old 03-03-2013, 12:11 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
4 #8's would not be compliant in 1/2".
We would have to know the distance above the rooftop the conduit was running and the area you are in. I'm guessing you will have to upsize the conductors. How much, don't know yet.
Old 03-03-2013, 01:00 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 470
Fill has the same issue along the wall, floor or rooftop.
Derating factors come into play on a rooftop install.
jbfan is online now   Reply With Quote
Old 03-03-2013, 01:15 PM   #5
Rewards Points: 187
Thanks a lot for you comments so far!
The run will originate at the main service panel on the exterior building wall. From there it runs straight up (about 5ft) and will penetrate through the eave onto the top of the roof. At about 4 inches above the roof surface it will turn 90 degrees (will probably use an LB) and run horizontally over the roof surface for about 3ft max. to a junction box.
This will be for a solar PV system. Currently the load will only be about 17A but:
1) I have lots of 8 AWG lying around which I can use
2) using 8 AWG will have the benefit of having a little room for further expansion of the PV system
Thoughts?
Old 03-03-2013, 01:48 PM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thoughts?
You might want to read up on the NEC for all the requirements for installing a PV system... not just wing it...
Old 03-03-2013, 02:07 PM   #7
Rewards Points: 826
Thoughts?
Are conduit fill rules the same for DC as they are for AC? I assume PV output is DC current.
curiousB is online now   Reply With Quote
Old 03-03-2013, 03:04 PM   #8
Oso954's Avatar
Rewards Points: 1,106
In most cases it is. But, there are systems that are installed with microinverters on each panel. The output from these would be 240V AC.
Oso954 is offline   Reply With Quote
Conductors in Raceway brookny Electrical 8 11-12-2011 12:38 PM
To fill, or not to fill? IRuehl Landscaping & Lawn Care 7 08-27-2011 04:30 PM
residential surface mount raceway toddmpa Electrical 3 02-14-2011 08:31 AM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 08:14 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 06:19 AM
