Raceway/Code Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2010, 07:37 PM   #1
Hi all:
Quick question about how to handle a run of romex from a fixture till it hits the drywall.
Its about 6 or 7 feet from the ceiling of closet around and down a few corners, then straight shot of about 10 inches through drywall into the back of the remodel box.
It doens't have to be gorgeous because its inside the closet, but what is the code-compliant way to use a raceway or similar product to secure and cover the run and any required transition/bushing for the entry into the drywall.
Probably pretty basic but I couldn't find a post on this topic already existing.
schnitz411 is offline   Reply With Quote
Old 03-09-2010, 10:05 PM   #2
Registered User
Termite's Avatar
I presume we are talking about romex wire running on the outside of the wall, exposed to the closet. That would be a code issue because the wire is subject to physical damage.
Check out a product called wire mold. It is a nice/legal way to dress up a wire like what you're describing. Pretty widely available stuff.
Old 03-09-2010, 10:06 PM   #3
Registered User
Termite's Avatar
Here you go:
http://tools.wiremold.com/diy/
More specifically...
http://tools.wiremold.com/diy/produc...ic_raceway.asp
Old 03-10-2010, 07:44 AM   #4
Master Electrician
Rewards Points: 3,958
the simplest and cheapest method would be to sleeve the NM with pvc conduit(RNC).
brric is online now   Reply With Quote
Old 03-10-2010, 08:21 AM   #5
Just call me Andrew
Rewards Points: 1,020
PVC conduit isn't as aesthetic as wiremold....but it is cheaper.
I thought romex wasn't supposed to be inside conduit, aside from a very short run to protect it from damage. Would this closet run warrant individual THHN wires?
Andrew
secutanudu is offline   Reply With Quote
Old 03-10-2010, 08:54 AM   #6
Master Electrician
Originally Posted by secutanudu View Post
pvc conduit isn't as aesthetic as wiremold....but it is cheaper.
I thought romex wasn't supposed to be inside conduit, aside from a very short run to protect it from damage. Would this closet run warrant individual thhn wires?
2008 nec 334.15(b)
Old 03-10-2010, 09:03 AM   #7
Just call me Andrew
Originally Posted by brric View Post
2008 nec 334.15(b)
I guess it doesn't say anything about NOT using conduit with cable for long runs, but I have heard it mentioned here a few times.
Andrew
Old 03-10-2010, 09:10 AM   #8
Master Electrician
We sleeve it all the time in RNC, LFNC, and EMT.
Old 03-13-2010, 03:39 PM   #9
Went with the wiremold and worked out great. Thanks for the suggestions.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
