R There Any Bad Effects For Over Sizing Wires? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-15-2013, 01:42 PM   #16
JOATMON
ddawg16's Avatar
Rewards Points: 840
Originally Posted by Dorado View Post
Your comment about logic is the only thing I disagree with. I keep reading that bigger is fine but even if there's no lug problem I bet there's either a specialty wire so thick that's being used somewhere what would cause a problem, or else there's a theoretical wire so thick that it would cause a problem. If you dig a long ditch, about 5' x 5' wide, and fill it with molten wire grade copper and wait for it to harden and try powering household stuff with it, don't you figure there would be a problem?
It would only be a 'problem' if the pit was not properly insulated to isolate it from earth.
Old 03-15-2013, 01:54 PM   #17
So at least you agree that a conductor as large as the earth would be too large. If a chunk of pure copper the size of the earth were insulated, you don't think that would work well, do you?
Dorado is offline   Reply With Quote
Old 03-15-2013, 02:02 PM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 840
Your changing the scope....
Your previous post refer'd to a 5'x5' conductor of solid copper. Assuming it was properly insulated, it would not be a 'technical' problem. Practical? No....a Problem? No.
A conductor the size of the Earth? Well, it already is a conductor.
Now we are getting off topic and a bit ridiculous...
Back to the OP's original question....would installing a larger conductor than what is required for the current installation be a problem? No.....there are no 'technical' reasons that would create a problem. Is it practical? Depends on what kind of wire and how much bigger.
The Following User Says Thank You to ddawg16 For This Useful Post:
jbfan (03-15-2013)
Old 03-15-2013, 03:28 PM   #19
thank you DDAWG and everyone who took the time to be helpful
thanks ddawg and everyone who took the time to be helpful
Theres always a few advocates who seem to like to sway the topics off course, out of amusement.
Fine with me...
davidshultz2007 is offline   Reply With Quote
Old 03-15-2013, 04:39 PM   #20
Rewards Points: 1,214
Originally Posted by dorado View Post
so at least you agree that a conductor as large as the earth would be too large. If a chunk of pure copper the size of the earth were insulated, you don't think that would work well, do you?
wwwwhhhhaaaaaaaaaaaaatt???????????? Kook time
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 03-15-2013, 05:24 PM   #21
Electrician
Rewards Points: 760
There is a point of overkill when sizing wires. If the wire you selected covers your load and any voltage drop, going bigger will not give you any benfits except a lighter wallet.
darren is offline   Reply With Quote
Old 03-15-2013, 06:14 PM   #22
I just wanted to see whether there's any diameter so large that he would think "that may not work." I bet there's information on the theoretical upper limit to the diameter of a wire for effective household use, and it has to do with something other than practicality or cost, and I bet a 5' x 5' thick wire would be too large. Theoretical electrical engineering doesn't need to be taught to even master electricians and the generalizations you all make are fine, practically speaking, but I bet the exact truth would contradict you on this. There is nothing logical about thinking there's no wire too large.
Old 03-15-2013, 09:21 PM   #23
Electrical Enthusiast
Rewards Points: 504
As long as it fits under the lugs and is rated for whatever the conditions are, I personally think bigger is always better. You will have less voltage drop for your batteries.
Also, what are you considering running off of your battery(s)? I was considering some sort of turbine/battery setup myself.
Kyle_in_rure is offline   Reply With Quote
Are Dead wires allowed or unsafe? Scooby333 Electrical 31 10-01-2012 02:26 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 03:55 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 02:35 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
