Quick Wire Size Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 05:50 PM   #1
I am adding an addition to my house and am going to install a sub panel to service the addition.
My main panel in the existing structure is 200 amps. The sub panel is 100 amps.
My question is - what size feeder wire do I need from the 200 amp box in the existing structure to the new 100 amp sub panel? I am considering both aluminum and copper and wonder if there is a difference in wire size between the two.
BTW, the sub panel is about 30 feet from the main panel.
Any advice would be much appreciated.
Thanks!
Bill
leeave96 is offline   Reply With Quote
Old 08-22-2011, 05:55 PM   #2
Code05's Avatar
Rewards Points: 1,104
#3 copper or #1 aluminum. What code cycle are you on?
Code05 is offline   Reply With Quote
Old 08-22-2011, 05:57 PM   #3
I don't have a clue. Let's assume the latest until I can find out.
Bill
Old 08-22-2011, 06:02 PM   #4
Code05's Avatar
Bill
Are you using conduit/pipe or SER cable? If a SER cable, are you going through insulation?
Old 08-22-2011, 06:14 PM   #5
Most likely SER. No conduit or pipe. Not going through insulation, but am going through/recessed between 2 x 8 floor joists. One of the reasons I'm asking about copper vs aluminum is to potentially minimize the hole diameter cut-out for the wire bundle so as to minimize the structural impact the hole through the 2 x 8 will have. Someday I may insulate, but don't have too. How would that impact the wire size? BTW, this is a basement run vs an attic run from a temperature standpoint.
Thanks for the help!
Bill
Old 08-22-2011, 06:33 PM   #6
Code05's Avatar
Bill
For the same amperage, copper is smaller than aluminum.
Under 2011 NEC rules, SER can be rated at 75C degrees if no insulation.
2008 NEC limited it to 60C degrees only.
Ground rod and ground wire question mulltron Electrical 17 07-29-2011 06:10 PM
Ground Wire Size Question Suprageezer Electrical 12 07-28-2011 04:00 PM
Important Wire Nut and Electrical Tape Question Wolfies167 Electrical 22 01-06-2010 01:59 PM
wire size for ac/heating forced air unit macfluke Electrical 2 03-04-2009 01:29 AM
What size wire and what kind of conduit... epeterson777 Electrical 15 02-21-2009 08:43 PM
