Old 05-21-2007, 12:30 AM   #1
Quick Question on Powerstrip Install
I'm installing a hard-wired powerstrip (Plugmold from Wiremold). I plan on installing it directly below an existing outlet.
What I would like to do is run Romex from the existing outlet down behind the drywall and just make a small hole for the Romex to exit the wall (i.e. no box). The strip has 1.2" knockouts on the back and I would love to be able to install it cleanly. Since the strip has knockouts, is it technically a box? and can I just secure the romex to the box and be up to code?
Thanks for any help.
Ferguson is offline   Reply With Quote
Old 05-21-2007, 07:17 PM   #2
Good luck fitting the wire nuts.
Master Electrician
jwhite is offline   Reply With Quote
Old 05-21-2007, 09:14 PM   #3
************! You're right. Back to the surface mount method. Thanks.
Old 05-05-2010, 09:27 PM   #4
Similar problem here. Our electrician installed a (surface) box at the end of the plugmold. Problem is it has height of 1 1/2" and the light rail is only 1 1/4". There does not appear to be any alternative box that is smaller. Any suggestions? About fitting the wire nuts: are there special smaller ones? that we could use? Thanks.
linochka28 is offline   Reply With Quote
Old 05-05-2010, 09:32 PM   #5
Licensed electrician
Wiremold makes boxes in different depths. IIRC the thinnest is 13/16". They may have installed a box that deep because the capacity was needed.
Old 05-05-2010, 09:51 PM   #6
Red face
It could be done. With some sweat and twists and turns. i.e; twisting the Angle connector instead of the locknut and "Squeezing" the Yellow (Medium) wire nuts.!
spark plug is offline   Reply With Quote
Old 05-06-2010, 12:58 AM   #7
Journeyman Wireman
Use a two hole Wago connector. Wago is a brand name for a push in connector. We use the small yellow ones for wire mold. http://www.wall-nuts.us/store773.cfm
Jupe Blue is offline   Reply With Quote
The Following User Says Thank You to Jupe Blue For This Useful Post:
linochka28 (05-06-2010)
Old 05-06-2010, 07:16 PM   #8
Wiremold makes a connector that fits. Check page 3 of this PDF:
http://www.legrand.us/Wiremold/Raceway/Plugmold-Systems/Steel/2000-Steel-Multioutlet-System/~/media/533534A6523D48FCA163BB2881EE0C61.ashx
Part number is W30.
brich is offline   Reply With Quote
F chanell install question... TonyW Building & Construction 1 08-01-2007 11:34 PM
Vent stack leak and install question bjstewa Plumbing 5 06-09-2007 10:01 PM
framing an awning...quick question sjrhome Building & Construction 7 12-03-2006 12:24 PM
Laminate Selection & Install Question sdcards Flooring 1 10-13-2005 05:12 PM
