Old 12-26-2007, 12:33 PM   #1
Quick question (I think)
I have a hot wire (capped w/ wire nuts) running to a box awaiting an outlet. From this same box is a wire (not connected to ANYTHING) running to another box, also awaiting an outlet.
The induction type circuit tester shows BOTH wires to be hot, but the voltmeter indicates that there is no current flowing through the unattached wire.
Is the second, unattached, wire picking up some minor current from the hot wire by induction?
Thanks,
Potomac101
Potomac101 is offline   Reply With Quote
Old 12-26-2007, 07:25 PM   #2
Electrician philosopher
probably.
Andy in ATL is offline   Reply With Quote
Old 12-26-2007, 08:35 PM   #3
Definetly maybe.
220/221 is offline   Reply With Quote
Old 12-27-2007, 05:42 AM   #4
How is it that the unattached wire shows a current with the induction tester but nothing with the voltmeter?
Potomac101
Old 12-27-2007, 07:46 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Phantom voltage
Speedy Petey is online now   Reply With Quote
Old 12-27-2007, 07:25 PM   #6
Spooky scary bloodsucking phantom voltage that disappears when a load is applied to the wires. There is a cool demonstration on a pro's site that shows 120V worth of induced voltage on a wire that is completely unattached from any power source. This is why solenoid type testers are the best, in my opinion for homeowners. They apply a small load (voltage makes them vibrate, often) and make the scary voltage go away.
Andy
Old 12-28-2007, 12:54 PM   #7
J. V.'s Avatar
Andy, I havent had/used a wiggy in many years. But your statement has got me thinking about going out and getting one.....Thanks John
Hi from MA and a quick question laurawoof Introductions 4 10-19-2007 04:26 PM
quick bath tub question bathroomrenovator Remodeling 2 10-08-2007 12:51 AM
Painting a door red outside, white on the inside - quick question joeyboy Painting 6 08-26-2007 04:37 PM
