Quick Question - Determining Which Wire is Which (both dead wires)
Hi,
I ran two 12/2 cables from my basement to the attic, now I can't figure out which one is which. I don't have any fancy current detectors, and if I did, please suggest which type to buy for not too much money. I need to attach a power source obviously, and connect the current at the other end with some sort of indicator (light bulb)...I tried a 9V battery and 4W lightbulb - that failed. Please suggest a quick trick to figure out which wire is which, without hooking up to the circuit breaker panel... Thanks again for your help! |
Borrow or get a cheap DMM
http://search.harborfreight.com/cpis...eter&Submit=Go *On one of the cables strip the end of the Black & White wire and twist them together. *On the other end with the DMM set to read resistance measure each pair to determine which is shorted. |
You need a continuity tester. I make them from a 9V battery, a 9v pizeo buzzer and alligator clips. http://i8.photobucket.com/albums/a8/...2/DSC02067.jpg With tools you probably have around the house..... Cut the male end off of an old extension cord and wire nut it on to one end of the 12/2. Plug it in and check power at the other end. Obviously do this in a safe manner :jester: |
I like the 12v continuity testers with led. Works great for short detecting.
Look at the writing on the cable.
It is directional and there is a chance that one is going a different direction from the other. |
I ended up using a LED light from circuit city and a 9V battery, with one of end the wire being pigtailed and taking the battery and light to the other.
Strangely, the LED light burnt out rather fast. Good thing there were 2 in the package, FOR FOUR DOLLARs! wow. I should have bought a tail light or something for the same price and ripped the lights out! Maybe this is why CircuitCity went out of business in the states! |
Leds operate on current. They are diodes with a threshold voltage that only work with the right polarity as you must have found out. Since they operate on current instead of voltage they need a current source commonly through a resistor, the more current the brighter the Led. The current limiter is not built into the Led. For a short time you must have had a LED that flashed like a tail light. for more information: http://www.theledlight.com/ledcircuits.html . |
seriously
I think my continuity tester was less than $10
I kept asking for the continuity tester but Rona and Circuit City don't carry them, and afterwards I found one at HomeDepot. But, the LED game was fun for the price of a coffee and a good chat. :)
Wow.
Most DMM's have a built-in continuity tester with an audible beep that can be found at nearly any hardware or electronics store. Circuit city likely carries a DMM that is realtively in-expensive and does more than just check continuity. |
I'd say 99% of the people working in sales at big box stores of any type have no idea what they're selling. |
Radio shack, Audible continuity tester for $5 + some electrical tape.
http://i8.photobucket.com/albums/a8/...2/DSC02067.jpg |
| All times are GMT -4. The time now is 07:45 PM. |
