**Quick Help Please :) Simple Switch DIY - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2010, 06:39 PM   #1
**Quick help please :) Simple switch DIY
Hi All,
Trying to connect a flood light and realized the switch didn't work. I opened it up and see the following, how should it go? I saw some diagrams on Google but I don't want to screw it up.
Thanks... Light is currently off so I just need to finish this up....
jmejiaa is offline   Reply With Quote
Old 07-28-2010, 06:55 PM   #2
Is that the switch you just took out of the box? If so, how was it wired?
jerrymeek is offline   Reply With Quote
Old 07-28-2010, 07:00 PM   #3
It wasn't... I posted a pic of the box and the switch exactly as I found them... The old owner just left it like that..
The box has 2black and 2white.. I'm assuming those go on this switch, just don't know how.
lol... Those beers were drank a while ago. not now :P
Old 07-28-2010, 07:05 PM   #4
What I have researched seems to tell me the two black will go on the switch and the 2 white will stay connected as they are??
Old 07-28-2010, 07:13 PM   #5
Electrician
Proby's Avatar
That seems logical. HOWEVER, you said earlier that the light currently does not work. So inserting the switch won't make it work either, unless you find some other reason why the light isn't working.
The switch will simply break those two black wires. But they are currently connected so the should work. That's why I suspect that there is something else going on here...
Proby is offline   Reply With Quote
Old 07-28-2010, 07:15 PM   #6
The light does work....
What I rly meant was the light doesn't work with the switch...
Currently the floodlight is in and constantly on.
Old 07-28-2010, 07:18 PM   #7
Electrician
Proby's Avatar
Ok, well you lied!
Just put each black on each screw of the switch and you're set. Make sure the power is off.
Old 07-28-2010, 07:25 PM   #8
Ok, well you lied!
Thanks... Switch doesn't seem to hold the wire in the hole and looks broken....Off to HD.
Old 07-28-2010, 07:26 PM   #9
Electrician
Proby's Avatar
Wrap the wire under the screws.
Or better yet, pickup two switches and a cover plate and make it look nice and new.
Old 07-28-2010, 08:35 PM   #10
I just got a new switch... HD is 5 min away...
SUCCESS flood light installed YAY....
Now my light bulbs are just too bright and hurt my eyes.....
Thanks guys!!!
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 05:04 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
GFCI switch to control outside outlets billgeo Electrical 14 09-08-2008 11:09 PM
