Quick GFCI Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 07:26 PM   #1
Question
Quick GFCI Question
Ive currently got 7 plugs being fed from a junction box, they are the only thing on the whole circuit. Can i come out of that same junction box and run a wire to my washroom and put a gfci on it or will that screw up the whole plug circuit in the other room? (the other room is not a bedroom)
Stupid question maybe but thanks for the help.
mj876 is offline   Reply With Quote
Old 06-01-2010, 07:29 PM   #2
Electrical Contractor
kbsparky's Avatar
Define "washroom"
In the US, if this is a "bathroom" then you are not permitted to install an outlet in there using the same circuit that supplies other areas.
If your "washroom" is not considered a bathroom, then there should not be any problems with that setup.
-KB
Old 06-01-2010, 07:31 PM   #3
Yes it is a bathroom. But it is Canada if it makes a difference. Its got a toilet/shower/sink.
Old 06-01-2010, 08:08 PM   #4
joed's Avatar
Rewards Points: 12,904
In Canada bathroom/washroom GFCI can be on a circuit with other things. It is not required to be dedicated to the bathroom. You are still limited to 12 devices on the circuit.
A washroom has a toilet and sink but no tub or shower.
A bathroom has a tub or shower.
The Following User Says Thank You to joed For This Useful Post:
mj876 (06-01-2010)
Old 06-02-2010, 05:12 PM   #5
Master Electrician
actually the circuit for the washroom or bathroom is not allowed to run anything else but plugs in the bathroom. You may have a 15a gfci in your bathroom and run the lights in the bathroom off it as well. If you install a 20A gfci then the lighting needs its own circuit as the lighting is not allowed to be on a circuit bigger than 15A by code.
The CEC states that any room with a washbasin, tub, or jacuzzi is considered a bathroom with regards to gfci's(so if you put a jacuzzi in your bedroom all the plugs in that room need to be gfci protected).
so no you will not be able to tap off that circuit for the bathroom power.\
They flipped the entire code upside down with regards to all this stuff in 09....i was reading for weeks :D
andrew79 is offline   Reply With Quote
Old 06-02-2010, 06:52 PM   #6
joed's Avatar
D
Can you give me code reference for this because this is on the Ontario ESA FAQ Site
Question
Is a separate circuit required to supply a receptacle in a bathroom?
Answer
The code does not require a separate circuit for bathroom receptacles. Bathroom receptacles can be supplied by a general purpose circuit that supplies other general purpose receptacle and lighting outlets. Multiple bath and washrooms are permitted to be supplied by the same circuit. Rule 8-304.
In bathrooms where heavy loads such as hair dryers may be used it is recommended not to combine multiple bathrooms on the same circuit.
Ontario Electrical Safety Code 24th Edition/2009
andrew79 (06-02-2010)
Old 06-02-2010, 07:25 PM   #7
Master Electrician
8-304 actually doesn't say anything about bathroom receptacles. I did find it though in a handbook i have and you are indeed right. I personally never do it and assumed you couldn't....seems like a good way to trip breakers constantly. the whole tamper proof thing is becomming a royal pain in the @@@ though
any day i learn something new is a good day
Old 06-02-2010, 08:02 PM   #8
Alright guys thanks for the help.
GFCI outlets question bigcaddy Electrical 12 11-11-2009 01:22 PM
GFCI question. Please Help. the banana k1ng Electrical 4 10-09-2009 07:35 PM
code question - AFCI / GFCI breakers Red Squirrel Electrical 15 09-17-2009 11:16 AM
GFCI question: can line and load wires be run inside the same conduit? thegonagle Electrical 32 04-16-2009 06:07 PM
GFCI feeing subpanel question scott2332 Electrical 45 02-28-2009 03:15 PM
