Quick & EZ Question On Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2008, 10:13 AM   #1
Quick & EZ question on outlets
Hey guys-heres an easy one for you guys in the know-
I've got one single outlet on my back porch. Can this be converted to a double without additional wiring from the box?
Getting into the wall and changing the box is not a problem, I just want to make sure that I'm not violating any codes or doing anything that is unsafe.
elscorcho is offline   Reply With Quote
Old 05-22-2008, 10:20 AM   #2
Rewards Points: 1,188
On a residential convenience circuit, you can have as many receptacles as you like, there is no limit.
LawnGuyLandSparky is offline   Reply With Quote
Old 05-22-2008, 10:29 AM   #3
When is fishing season?
CowboyAndy's Avatar
I assume that you mean duplex (2 outlets in 1 receptacle) and want to add another and plan to change out the single gang box to a double. There is no problems with this. But, being a porch it should have GFI protection... DDo you know if it currently had this?
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 05-22-2008, 10:54 AM   #4
I should have mentioned that it currently does not have a GFCI-its an old house and I'm sure this outlet is the original.
I planned on installing GFCI's-does this pose a problem?
Old 05-22-2008, 11:54 AM   #5
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
No problem. Just wire the 2nd duplex from the load terminals of the GFCI and both will be protected.
John
jrclen is offline   Reply With Quote
Old 05-22-2008, 11:56 AM   #6
Power Gen/RS Engineer
Rewards Points: 566
Not at all. If you install a GFCI recept. in place of the old one, the additional duplex recept (non-GFCI) will be wired off of the GFCI's load terminals. And don't forget to apply the little sticker thingy on the non-GFCI recept.
HA! You beat me to this one, John!
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 05-22-2008, 03:59 PM   #7
Thanks everyone-don't know what I'd do without you !
Old 05-23-2008, 09:17 AM   #8
jrclen's Avatar
Rewards Points: 514
You would ask in Yahoo Answers and get 20 wrong answers. All different.
You're welcome.
John
Question about wiring outlets together firemanpato Electrical 5 01-05-2008 03:52 PM
Another Dumb question - Self grounding outlets robertmee Electrical 9 10-25-2007 01:49 PM
quick bath tub question bathroomrenovator Remodeling 2 10-07-2007 11:51 PM
