Old 01-08-2011, 11:49 AM   #1
Quick electrical question - changing light switch.
I'm wishing to replace an old dimmer switch (DS) with a single pole switch (SPS). I want to make sure the following is correct. See the attached picture for reference. I'm planning to disconnect the DS's two black wires inserting the SPS and reconnect the two black wires to the SPS. Then connect one of the three copper wires to the SPS (green). Does it matter which of the three coppers I connect to? or any other advice? Thx.
cm3putter is offline   Reply With Quote
Old 01-08-2011, 11:50 AM   #2
Experienced
Jackofall1's Avatar
Correct and no
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
electrical plug and switch Linda Patterson Electrical 3 05-10-2010 07:55 PM
Fitting dimmer switch to old electrical wiring hugomax69 Electrical 0 01-29-2010 08:40 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
question moving light switch niemie13 Electrical 4 01-09-2009 03:12 PM
