Quick/easy Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 07-19-2008, 03:51 PM   #1
the Musigician
DangerMouse's Avatar
Question
quick/easy questions
hi everyone!
the plastic blue outlet boxes say outlet/switch, the gray says only SWITCH, hence i cannot use the gray for outlets? also, can I screw through the plastic with say, a drywall screw into the wall stud to make it tighter than the 2 nails?
tnkx!
DM
Old 07-19-2008, 08:02 PM   #2
Master Electrician
JohnJ0906's Avatar
Originally Posted by MdangermouseM View Post
hi everyone!
You can use these boxes for receptacles. Not a problem. Check the cubic inch size - I like larger ones for GFCIs.
tnkx!
DM
That is technically a violation. And the nails hold it plenty tight.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Tags
blue , boxes , outlet , plastic
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 03:06 AM
Range Hood venting questions Crashless Remodeling 5 04-13-2008 09:30 PM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 05:06 PM
some questions on masonry/cement/concrete (general q's) joeyboy Building & Construction 20 06-25-2007 08:53 PM
