Quick Code Clarification - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2010, 10:54 AM   #1
Quick code clarification
So when running romex, can romex be run in notches on a joist if a nail guard is installed? Do I have to staple the romex? I could just look this up in the code book but I need a quick answer.
rgsgww is offline   Reply With Quote
Old 02-20-2010, 11:07 AM   #2
jlhaslip's Avatar
Rewards Points: 1,574
should be stapled within 8" of entering/leaving a box.
should be minimum of 1 1/4" from the stud/joist face otherwise a plate is required.
Your local code might have different rules. confirm by calling a local electrician, or wait for another reply.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-20-2010, 11:27 AM   #3
Thank you, I've found what I needed
time to wire!
Couple of quick code questions re: placing receptacles tigereye Electrical 4 11-30-2009 03:42 PM
Two Quick NEC Code Questions Nozler Electrical 23 06-15-2009 11:16 PM
Smurf (flex ent) use Code clarification jamiedolan Electrical 7 02-04-2009 12:30 AM
Code Clarification GoyimPersuasion Electrical 24 01-28-2009 03:44 PM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
