Quick Bathroom Plug And Switch Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 02:17 PM   #1
Quick Bathroom Plug and switch Question
All,
I am in the process of finishing out my basement bath addition. I have a easy code question before I install the GFI and the decora switch. I ran a 20 amp dedicated circuit 12/2 to the bath. Inside the bath is a 1900 box by the sink to house the GFI for the room and the switch for the fan/light combo. These are the only devices in the bath.
I am wiring the breaker to the line side of the GFI - load side to the switch - switch to the fan light combo in the ceiling. That way the switch is protected by the GFI.
would I be ok by code with a 15 am GFI and 15 amp switch, or would they have to be 20 amp rated as they are the only things on that circuit. I know if I were to jump to another bathroom outlet then it could be 15 amp. But then if the GFI is the only thing on the circuit it will need to be rated to 20 amps.
Please help clear up my confusion.
Thanks.
mclemenc is offline   Reply With Quote
Old 01-30-2011, 02:25 PM   #2
Ravenworks's Avatar
Originally Posted by mclemenc View Post
All,
would I be ok by code with a 15 am GFI and 15 amp switch, or would they have to be 20 amp rated But then if the GFI is the only thing on the circuit it will need to be rated to 20 amps.
Thanks.
no confusion here,it has to be 20 amps
Ravenworks is offline   Reply With Quote
Old 01-30-2011, 04:09 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Hopefully a real electrician will jump in, but that is not my understanding.
As long as there are more than 2 receptacles on a 20 amp circuit, you can use 15 amp devices. A duplex receptacle counts as 2 receptacles.
That being said, using a 20 amp GFCI and a 20 amp switch would not hurt other than a little more cost.
BTW, you do not have to put the switch and fan/light combo on the load side of the GFCI(unless over the tub or shower). That way if the GFCI trips you are not in the dark.
Coastal South Carolina
Old 01-30-2011, 04:15 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
Unless you are in Canada, then a 15 amp device is fine.
I would wire the switch to the load side also, unless you are installing the fan over the shower/tub!
Old 01-30-2011, 04:23 PM   #5
A "Handy Husband"
rjniles's Avatar
jfan
Did you mean to say line side?
Old 01-30-2011, 11:02 PM   #6
jbfan's Avatar
Rewards Points: 252
Originally Posted by rjniles View Post
jfan
Yes I did.
Thanks for catching that.
How do I provide power to a plug when changing single pole 3 wire to 3-way switch Morris12 Electrical 4 01-05-2011 09:41 PM
electrical plug and switch Linda Patterson Electrical 3 05-10-2010 07:55 PM
wiring switch to gfci plug wendl Electrical 5 04-05-2010 10:02 PM
adding a plug from a switch that has red,white,black, and bare Limit54 Electrical 18 03-09-2010 08:14 AM
Switching from light socket to plug - stupid question CGofMP Electrical 5 03-25-2005 10:48 PM
