QUICK ANSWER PLS Concrete Over UF Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 04:32 PM   #1
Rewards Points: 41
QUICK ANSWER PLS concrete over UF cable
I'm putting 2 4x4 posts in the ground, set in quickcrete. I'll need to pour the concrete around, next to, and over two pieces of type UF direct buried electrical wire I buried in the same piece of ground last summer. They are 20-amp 12 gauge and a 30-amp 10 gauge cables, two conductors plus a ground, each. Each one is on its own dedicated breaker in my main panel.
I don't know what damage long term contact between concrete and type UF cable insulation would do. Am I risking damaging the circuits sometime in the future? I don't want to do that.
Can I put the concrete right in contact with the cable insulation? I'm willing to immobilize the cables by doing this. Or do I need to move the cables 6-12" to the side to get them out of the way of where the posts need to be (I can, but it'd be a LOT of extra work). Or should I put something in between them and the concrete? If I need to put something in between the concrete and the cables, what should I use? scrap plywood? good ol' duct tape around the cables? saran wrap or tin foil? just kidding...
Thx...
tomseeley is offline   Reply With Quote
Old 04-05-2011, 05:15 PM   #2
Rewards Points: 324
art.340 of nec say's no.
oleguy74 is offline   Reply With Quote
Old 04-05-2011, 07:00 PM   #3
I'd put pvc electrical conduit (gray) through the concrete and run the wire through the conduit. That way you'd be able to replace the wire easily in the future if need be.
jayel1 is offline   Reply With Quote
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 12:00 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
Need a quick answer...canned light wease Electrical 5 12-11-2006 10:54 AM
