#16 |
Questions regarding 100amp service and panel upgrade
We just bought an older house with a 100 amp panel and service, and I had them upgrade the panel and service entrance to 200 amps. It cost me about $2000, although obviously what needs to be done on your house may be very different from mine. If you're going to redo a significant amount of the house, you should consider upgrading to 200 amps, as it may be cheaper than doing just a panel upgrade now and service upgrade later. If you're going to consider central air eventually, definitely get 200 amps. For us, the power company is responsible for upgrading the wire from the street to our service entrance, so that saved us some money, particularly because it's above ground.
I'd definitely do the panel upgrade before the kitchen, because you're likely to need new circuits, i.e. you need 2 circuits for just the counters, a seperate one for the refrigerator, one for lights. We have 5 planned for the kitchen, so if you don't have room now, you should plan for a new panel/service upgrade. |
#17 |
I agree, get the panel before you do the kitchen.
Also, you really should do a load calc. you may not need 200 amps.
#1 - If you don't know what you're doing - get a licensed electrician! #2 - If you follow my advice and something bad happens see # 1 Electricity bites hard, and it could be the last thing you feel... Good Luck! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#18 |
I was told that for 100 amp service you could have no more than 20 breakers, 150 = 30 200 = 40. If that is true, then you also need to consider how many circuits you will have/add etc... we found we ended up using more circuits just to logically divide up the house, than we would really ever need load wise. i.e. we need 31 circuits by my current estimate, but realistically that's way over compensating, and we may not even use 60 amps. If that makes sense, all I wanted to point out that I believe that the number of breakers you can have is based on service size as well.
Is this correct? |
#19 | |
Electrical Contractor
Questions regarding 100amp service and panel upgradeQuote:
The only limit tothe number of breakers is the size of the panel.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
| The Following 2 Users Say Thank You to jbfan For This Useful Post: | rjniles (12-07-2012), stickboy1375 (12-11-2012) |
#20 |
Lic Electrical Inspector
There is no main breaker for the entire panel. It is a split buss panel and utilizes the "six motions of the hand" rule. The 60A breaker is the lighting main for the bottom section of ther panel. ZInsco breakers are notorious for failures. I once had a 15A breaker hold until the 200A main tripped. The panel meets code at the time it was installed. Barring any changes made after the initial installation.
All responses based on the 2011 NEC. If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Please check with local, county and state officials as laws may vary. Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Last edited by electures; 12-12-2012 at 10:27 AM. |
| The Following User Says Thank You to electures For This Useful Post: | asledge (12-10-2012) |
#21 | |
Now the question is only whether I should replace the Zinsco panel to a Siemens or better, and while doing so is it worth the extra 500 or 1000 for the upgrade to 200 amps. |
#22 | |
Interestingly, the only code violation I see is the doubled up wires on a few of the single pole breakers. The panel is otherwise compliant for the NEC in effect during construction. Your home inspector is a moron.
All responses based on the 2011 NEC. If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Please check with local, county and state officials as laws may vary. Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Last edited by electures; 12-10-2012 at 03:03 PM. |
#23 | |
All responses based on the 2011 NEC. If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Please check with local, county and state officials as laws may vary. Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . |
#24 | |
| The Following User Says Thank You to Dave632 For This Useful Post: | electures (12-10-2012) |
#25 | |
This is his estimate: Service Upgrade 100 Amp Installation of new 100 Amp Siemens panel 30 spaces Pass the electrical pipes to the new panel Installation of new breakers Price include all material and labor Siemens 100 Amp 30-Space 30-Circuit Indoor Main Breaker Load Center Model # P3030B1100CU Internet # 203027295 Store SKU # 593867 He is charging me $1000 even. The panel only costs $87. Do you think I could find someone else who will do it for cheaper than that? Does this too much just to update the panel? |
#26 |
The only way to know, is to get 2 more bids.
Do you want cheap, or done right ? |
#27 |
A "Handy Husband"
Price sounds good but make sure he gets a permit and the inspection. If he tries to get you to pull the permit, be wary.
| The Following User Says Thank You to rjniles For This Useful Post: | electures (12-11-2012) |
#28 | |
The lights in the entire house flicker when the dishwasher changes cycles, or when the fridge starts cycling back up. Will the panel upgrade fix this issue? Or is this a load capacity issue? The house is getting 100 amps already, but it's a 100 amp split-bus panel with a 60 amp 2-pole breaker. So I just need to make sure that if I upgrade the panel to the one I mentioned in my previous post, that the lights will stop flickering. Can someone comment on what causes/might cause the lights to flicker? Is this because of the breaker is not 100 amp main breaker, or because 100 amp service is not sufficient? Thank you. |
#29 | |
Lic Elect/Inspector/CPO
#30 |
Licensed Electrician
Is that price for a real service upgrade, or a panel change? I'm guessing the latter.
Not a fan of the new layout.
Answers based on the National Electric Code. Always check local amendments. |
| Display Modes | |
| 100amp service to 200amp service - double or single panel | CapeCod153 | Electrical | 8 | 05-09-2012 09:03 PM |
| Questions about 100-200A service upgrade | kwilcox | Electrical | 35 | 04-22-2012 06:15 PM |
| Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes | kalus | Electrical | 22 | 03-23-2012 03:09 AM |
| Upgrade from 100amp to 200 amp service: What can stay? | jimmyfloyd | Electrical | 11 | 01-09-2012 07:04 PM |
| Wiring Size Calculations for New Service | CorinthWest | Electrical | 7 | 12-07-2010 12:36 PM |
