I am doing under cabinet lights. it is the kichler linear system. i havent bought anything yet so i dont have it in front of me to figure it all out so i wanted to ask.
I will need a low voltage dimmer and transformer.
How does it normally go-- Line(120) voltage to dimmer switch then to the transformer?
the kichler linear system uses low voltage cable. do you think i could put the transformer in a central location and branch out left and right side or do i need to be at the beginning of the run?
reason im asking is i cant be longer than 30 feet of a run.
thanks
thanks
