Questions About Wiring A Line Voltage Thermostat - Electrical - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 03:51 PM   #1
Questions about wiring a line voltage thermostat
[x-posted from HVAC - sorry for the duplicate post. Doc Holliday suggested I post in this forum as well]
Hello DIYers,
I am attempting to replace a line voltage thermostat for my electric baseboard heater. I had a few questions, please bear with me:
The old thermostat has screw terminals where the wires attached (photo #1), but the new thermostat (photo #2) has wires directly attached. How should I attach these wires to the wires in the wall - wire nuts?
The old thermostat had a green grounding screw, but I don't see any such thing in the new thermostat (photo #2). Where does the ground wire from the wall need to go?
I am not sure how the wires match up. In the wall, there are 2 sets of wires - each set has 1 white and 1 black. In the new thermostat, there are 2 sets of wires - but each set has 1 red and 1 black. Does black go to black and red go to white?
There is some green corrosion and some blackening on a few of the wires in the wall. Could this be from moisture? Is the wire still OK to use?
It's hard to see in the photos, but the plastic electrical box in the wall is broken - a piece of the plastic broke off from the main one. Do I need to put a new box in?
Thank you so much - sorry for all the questions, you guys are always so helpful!
// Joe
Questions about wiring a line voltage thermostat-20120110_221507.jpg   Questions about wiring a line voltage thermostat-20120110_230245.jpg   Questions about wiring a line voltage thermostat-20120110_222450.jpg
thinksincode is offline   Reply With Quote
Old 01-11-2012, 03:53 PM   #2
MarginallyQualified
Rewards Points: 2,464
line to RED
load to BLACK
Done
Old 01-11-2012, 04:05 PM   #3
I=E/R
a7ecorsair's Avatar
The new thermostat is plastic so it doesn't require a ground.
Look in the instructions and verify which wires are line and which are load.
Does the thermostat have an OFF on the dial?
a7ecorsair is offline   Reply With Quote
Old 01-11-2012, 04:50 PM   #4
Rewards Points: 3,256
The wires have become too hot because of the faulty thermo or loose lug screws. Cut them back to where they are in good condition. Someone for the box question and you are good to go.
Nice meter BTW.
zappa is offline   Reply With Quote
Old 01-11-2012, 05:17 PM   #5
Mad Scientist
That box is both old, and broken. Since it appears to be mounted in an easily combustible surface, and from the look of those wires you've already come close to having some unanticipated combustion, I'd go ahead and replace the box. That box also kinda looks like it might have been too small for that many wires to begin with. You can cut/break out the old box, and install a remodel box in its place. You may have to slightly enlarge the wall opening.
McSteve is offline   Reply With Quote
Old 01-11-2012, 05:27 PM   #6
Licensed electrician
Rewards Points: 1,758
The line wires are labeled L1 and L2 on the T-stat.
McSteve (01-11-2012)
Old 01-11-2012, 05:36 PM   #7
Mad Scientist
Whoa, good catch.
Old 01-11-2012, 05:38 PM   #8
joed's Avatar
Rewards Points: 13,308
Looking at the picture it looks like black is one contact and the red is another contact. L1 is line and T1 is load(heater).
Old 01-11-2012, 05:42 PM   #9
Thanks for the confirmation.
Old 01-11-2012, 08:20 PM   #10
Yes, it has an OFF position.
Old 01-11-2012, 08:20 PM   #11
Which wire goes to which line wire on the thermostat? Do I match the black wire to the black wire and white to red? Don't want to hook it up backwards
Old 01-11-2012, 09:31 PM   #12
joed's Avatar
I would put the whites to the red air and the black to the black pair.
Old 01-11-2012, 10:41 PM   #13
As long as the pairs are correct to line and load it does not matter.
Old 01-12-2012, 03:07 AM   #14
Semi-Pro Electro-Geek
Rewards Points: 2,970
Interesting. There appears to be no consistent standard for the color coding of terminals on 2-pole thermostats these days. The last person who asked here (a couple weeks ago) I foolishly advised that the red pair would be one pole and the black pair the other pole. It was the only way that made sense to me. That resulted in a dead short! Each pole had one red and one black. This thermostat, on the other hand, is wired exactly as I had assumed. I guess the bottom line is that one must read the manual or use a meter to be sure.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
zappa (01-12-2012)
Old 01-12-2012, 07:48 AM   #15
I=E/R
a7ecorsair's Avatar
Since it has an OFF, that means both sides of the T-stat interrupt a power leg. If you don't have the manual and the wiring isn't labeled you will need a meter to check the two connections through the t-stat.
I just took another look at the picture and I clearly see L1 and T1 marked on the base. I'd guess the other side will say L2 and T2.
The L1 and L2 go to the supply power and T1 and T2 to the load.
heat pump wiring problem - new thermostat tygrr94 HVAC 8 01-17-2011 08:18 PM
Honeywell thermostat wiring wcb22 HVAC 5 01-10-2011 05:54 AM
Line voltage thermostat BLEW UP cupajoe HVAC 3 02-16-2010 09:30 AM
Line Voltage Thermostat Wiring bswigart Electrical 10 11-24-2009 07:10 PM
how to wire a low voltage thermostat to a baseboard heater db3iii HVAC 4 06-05-2009 08:03 PM
