Questions about upgrading electrical stuff in our house
Hello! Our electrical stuff in our house needs to be upgraded and my husband had a few questions he wanted me to ask about. Our house was built in about 1972 and is in Missouri, if that is helpful to anyone.
If this is not the right place to ask, please let me know if there is another forum that would be more appropriate. We need to: 1) replace fuses with circuit breakers 2) upgrade electric from 100 amps to 200 amps 3) move box over about 3 feet (too close to a wall now) which will also include splicing wire to extend that 3 feet. Questions are: 1) should we have wiring inspected for increased resistance due to aging? 2) If so, how is that done? 3) We need 2 outlets with ground fault interrupters outside, cables will need to go underground - what is the code for that? I have a couple questions too: 1 - How do we know how many amps our house needs? 2 - How do we determine if an electrician really knows what they are talking about or are any good? We don't have family in the area to ask for recommendations. |
1) Checking old wiring is a good idea just to be on the safe side, but could be time and money consuming. I would suggest checking areas where you think you might be having a problem or if you feel something might not be safe.
2) Upgrading your service to 200 amps is best thing you can do. If you intend at some point to remodel your kitchen, bath, basement or maybe even adding a second floor, this will definitely need to be done. Many local and national codes require several new circuits and a new 40 circuit panel will serve this purpose. 3) Installing conductors in a conduit rated for underground use is the way to go here. If you protect the circuit with GFCI protection before the conduit goes underground you will only have to dig down 12" instead of 18". 4) A good electrician will demonstrate confidence in all of his answers even if they are dumb questions. It is his job to have these answers and know them immediately. Never go with the lowest bidder. Hope this helps. |
How do you know how many amps you need?
See this link http://www.selfhelpandmore.com/home-...ation-2002.php |
Not if it's less than 20 amps. Table 300.5 Why not go with the lowest bidder? Simple, he may have miscalculated everything involved in the job and will look to cut corners. Good service, good installation, and a job done the right way costs money. |
But, for what it's worth, I'm just picking a nit. I knew what you meant:thumbsup: |
You actually made me go look it up which is a good thing. I thought to myself, "I've been doing it like that for years, how could I possibly be wrong"? |
You maybe able to ask for reference from neighbors and friends at work. Do not be afraid to ask the electrician questions. Make sure that they are licensed and insured! Don't be afraid to ask for a copy of their liabilty and workmens comp insurance if needed.
Gary |
| All times are GMT -4. The time now is 06:28 PM. |
