Questions About Subpanel 240V - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-07-2011, 01:12 PM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 464
Originally Posted by brric View Post
The cable is too large. 8-3 UF-B is 0ver an inch wide.
Gotha! Just came down from working on the roof, so the brain was a little fried!
Old 07-07-2011, 08:56 PM   #17
Electrician
SD515's Avatar
Rewards Points: 504
Originally Posted by jbfan View Post
Code says you can put 5 #8 thwn/thhn wires into 3/4 pvc conduit.
With one #10 and 3 #8's you should make it.
Make sure the wire is rated with THWN for a wet location.
MC cable would not be allowed inside the pipe.
And the #8 being run in conduit has to be stranded. The #10 for ground can be solid or stranded.
Also, 2 of the #8's can be any color other than white or green, black is the most common. 1 of the #8's has to be white. The ground wire has to be green or bare. I'd used #10 green stranded or #10 bare soild.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
mulltron (07-07-2011)
Old 07-07-2011, 10:51 PM   #18
Thanks for all of the help everyone! I feel confident now and have the info I need and appreciate everyone helping out the newbie! =)
mulltron is offline   Reply With Quote
240v questions.... ITSANSS Electrical 16 05-11-2011 05:40 PM
Pool subpanel questions Simbilis Electrical 3 04-23-2011 06:44 PM
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 02:23 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 09:45 PM
