Old 07-16-2012, 07:39 PM   #1
questions about my panel
I was looking inside my panel a few days ago and noticed a few things. There seems to be some sort of buildup or corrosion on the screws of the breakers. These are not the screws holding the wire in place, they seem to be holding the breaker together. Is this an issue? The panel is in a basement.
The other thing I saw was all the neutrals and grounds share a screw on the neutral/ground bar. The panel looks clean and well done so I wouldn't think a pro would mess up something that simple. The house was built in 1995 if the code has changed regarding this issue, thanks.
questions about my panel-forumrunner_20120716_193855.jpg   questions about my panel-forumrunner_20120716_193910.jpg
frylock11 is offline   Reply With Quote
Old 07-16-2012, 07:45 PM   #2
E2 Electrician
stickboy1375's Avatar
The neutrals and grounds sharing a single hole is a code violation, the white stuff on the breaker might just be part of the manufacturing process? not sure what it is...
Old 07-16-2012, 07:50 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
It is a sealant in a hole. Yes, it is normal and part of the manufacturing process.
Old 07-16-2012, 07:53 PM   #4
Electrical Contractor
kbsparky's Avatar
You can ignore that white stuff adjacent to the terminals. It's part of the manufacturing process and resembles porcelain.
-KB
Old 07-16-2012, 07:57 PM   #5
Originally Posted by kbsparky View Post
....... and resembles porcelain.
Yup, exactly.
I bet it is hiding a critical screw they do not want you to get at.
Old 07-16-2012, 07:58 PM   #6
E2 Electrician
Originally Posted by Speedy Petey View Post
Yup, exactly.
They don't want you to let all the magic out.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Speedy Petey (07-16-2012)
Old 07-16-2012, 08:03 PM   #7
kbsparky's Avatar
Yup, exactly.
Most likely a calibration screw. Most breakers have them, hidden behind a certification or lot# sticker...
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Old 07-16-2012, 08:08 PM   #8
E2 Electrician
Good call...
#6 would be the calibration screw in the picture.
Old 07-16-2012, 08:47 PM   #9
Thanks for the replies about the breakers. Should I worry about the ground/neutral issue or leave it alone?
Old 07-16-2012, 08:49 PM   #10
E2 Electrician
Lets see, the panel has been installed since 95, yeah, I wouldn't lose much sleep at this point.
it is an easy fix through, just make sure you turn off the breakers first, or you could end up with a nasty surprise.
Sub panel wiring and voltage drop questions CPF Electrical 6 11-30-2011 08:52 AM
More Sub Panel Questions rdkng07 Electrical 6 05-25-2011 09:46 AM
Critique my Sub Panel rjniles Electrical 18 05-18-2011 12:31 AM
New Breaker Panel Questions AvalonGirl Electrical 10 06-02-2010 11:20 AM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
