Questions About External Antenna - Electrical - DIY Chatroom Home Improvement Forum
Old 03-11-2012, 04:07 PM   #1
US ARMY RETIRED
ACR_SCOUT's Avatar
questions about external antenna
Hello,
I would like to install and external omni directional FM antenna to pick up the local radio stations. I am doing this because of a family room I am putting in the basement.
Is it possible to get an omni directional tv (VHF/UHF) antenna and merge the FM signal on the same RG6 so I don't have to run two cables?
Thank you,
Fred
ACR_SCOUT is offline   Reply With Quote
Old 03-11-2012, 04:26 PM   #2
Rewards Points: 756
Check your antenna.
I think you'll find your antenna will work just fine on the the FM band as well.
FM is located between channels 6 and 7.
AandPDan is offline   Reply With Quote
Old 03-11-2012, 07:22 PM   #3
Rewards Points: 3,256
I'm a little behind the times with technology but I thought I heard a while back that they were moving the over the air TV channels to 7 or 800mhz and going digital?
zappa is offline   Reply With Quote
Old 03-11-2012, 07:53 PM   #4
Rewards Points: 756
HDTV is digital but it uses the same frequencies allocated as before. Not many stations are using VHF frequencies, most are on UHF. The channels numbers you may see are often "virtual" channels. For example in the Boston, MA area, WBZ-TV is known as "channel 4" (as it was formerly chanel 4 on VHF) but now it broadcasts on DTV channel 30 (UHF) - although it will display as "4" due to data encoded in the digital stream.
You do need an ATSC receiver to receive and decode the new signals.
800 mhz is in the "old" UHF band. It is no longer used for TV broadcasting and the 700 mhz spectrum was auctioned off in 2008 (US).
An old antenna is fine. "Digital" or "HD" antenna's are just a marketing ploy.
The Following 2 Users Say Thank You to AandPDan For This Useful Post:
mpoulton (03-11-2012), zappa (03-11-2012)
Old 03-11-2012, 09:48 PM   #5
Thanks....it must be the small footprint of the replacement rabbit ear antennas I have seen that threw me off in my thinking.
Old 03-11-2012, 10:20 PM   #6
Rewards Points: 6,652
And that changes technology since Marconi why?
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Pre-wired coaxial cable mapping & digital antenna set up BadHand Electrical 6 10-30-2011 09:37 PM
Do I need a digital antenna? darsunt Home Theater 9 02-12-2009 11:00 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
questions about installing television antenna darsunt Home Theater 2 05-07-2007 01:16 PM
