QuEstionn - Electrical - DIY Chatroom Home Improvement Forum
Old 11-22-2010, 03:43 PM   #1
quEstionn
i am wondering how much lights/switches/receptacles i can put on a 60 amp circuit breaker
im wondering if i can do 6 lights 2-3 switches and 2-3 receptacles on 1 circuit.
massops is offline   Reply With Quote
Old 11-22-2010, 04:08 PM   #2
Licensed electrician
Rewards Points: 1,266
The code prohibits general usage circuits from being greater than 20 amps. However, I do not believe that is what you are really asking. Given the loads you listed you could probably just use two 15 or 20 amp circuits.
Old 11-22-2010, 04:29 PM   #3
ill go with the 2 20 amp circuits what wire dou reccomend i was thinking of using 12/2
Old 11-22-2010, 05:31 PM   #4
Rewards Points: 1,448
With a 60 amp feed, for example to a shed, you must run it to a subpanel where 15 and 20 amp branch circuits are then run to your lights and receptacles (outlets). To use a 20 amp breaker all the wiring including to the light fixture boxes must be 12 gauge or fatter. (The thin wires going into the fixture and to the lamp sockets are connected normally as-is.)
AllanJ is online now   Reply With Quote
Register Boot questionn tee777 HVAC 3 05-06-2009 12:16 PM
