Question Regarding A Sub-panel - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 04-02-2008, 08:51 AM   #46
When is fishing season?
CowboyAndy's Avatar
Originally Posted by jrclen View Post
Yes they are. But the manufacturers will be free to design panels as they wish. Those panel will still need to be tested and listed by a testing agency such as UL. Only the arbitrary limits will be eliminated. State and local codes may have something to say also.
So, any existing panel will still be bound to the limits set my the manufacturer at the time it was made, correct? If my panel limits a total of 40 breakers, 42 circuits total it would still be limited to that?
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 04-02-2008, 11:20 AM   #47
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Think about it for a second.....
Old 04-02-2008, 12:20 PM   #48
CowboyAndy's Avatar
Hey, only a few hours of sleep last night... brain not functioning...
MY HOUSE OWNS ME!
Old 04-02-2008, 08:23 PM   #49
to jrclen
attion jrclen
yes you are right about the max of breakers in a panel for 2008 code . but it is not in affect untill 2010, and do you know the reason why ? the reason is because of the ark fault, because they can not be twined
joed1234 is offline   Reply With Quote
Old 04-02-2008, 08:56 PM   #50
jrclen
yes u r roight about the 2008 code on breakers max in a panel , but will not be in effect untill 2010 , do u know the reason 4 this? the reason is because of the ark fault breakers u can not twin them so they [nec ] are letting u load up the panels with in reason.
Old 04-03-2008, 10:41 AM   #51
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Originally Posted by joed1234 View Post
jrclen
Do you have a link to this? I'd like to read it.
jrclen is offline   Reply With Quote
Old 04-03-2008, 10:51 AM   #52
UAW SKILLED TRADES
Stubbie's Avatar
So would I, thats news to me....
Old 04-03-2008, 10:39 PM   #53
Power Gen/RS Engineer
Rewards Points: 566
I like to harass the guys at Home Depot and Loews by asking them electrical questions. They don't have a clue. But to an untrained home owner, they sound pretty good. It's just good clean fun.
Funny indeed!
In the last few months, here are a couple of choice things I've been party to at my local HD:
1. [customer] I need some wire to install a new light fixture. Do I have to run it in that metal piping?
[HD Professional] Oh no, you can just use this Romex stuff. It's designed so that it doesn't need to go in conduit.
[me, to customer] Do you live in Chicago?
[Customer] Yes.
[me, to customer] Code requires that it be routed in pipe. You are not allowed to use NM cable.
[HD Professional, interrupting] Hey, man, I don't know about this "NM" stuff. I was talking about Romex. It's totally cool.
[me, getting annoyed with the HD Professional] It's not allowed in Chicago.
[HD Professional] Well then why do we sell it??
[me, being sarchastic] Perhaps for people who live in Schaumburg (municipality beyond Chicago rule)?
2. [customer] Do you sell those lights that are motion sensitive but only work at night?
[HD Professional] Well, you can buy this photosensor, and then you can buy this motion sensor and with the double-bulb socket thingy, you can make it.
[me] Uh, they sell those lights in the lighting department.
[customer] Really?
[HD Professional getting snotty with me] I'm sorry sir but there is nothing currently available that does all those things.
[me, holding up a Heath/Zenith motion/photo control light similar to the ones that I've installed 6 million times] Oh, like this??!
[HD Professional] Whatever. That's not what he was asking.
And perhaps the best,
[customer] I need some wire for a rewiring project. Do I need to buy #14 or #12?
[HD Professional] Is this for 120V? Actually, the 600V wire is for 480V AC. If you're just adding a 120V circuit, you can use this 250V we have over here. And, it's got 4 wires not just one!
[me, acting like Kevin from Home Alone] Ahhhhhhhhhh!
Scary, but fun/interesting!
TTFN,
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 04-04-2008, 10:30 AM   #54
jrclen's Avatar
Rewards Points: 514
Originally Posted by BigJimmy View Post
Funny indeed!
TTFN,
Jimmy
My favorite is the water heater. I asked about installing a water heater. I asked for the "Master Electrician" at HD. When he freed himself, I told him I wanted to install a water heater but I didn't know anything about electricity. He told me it was no problem at all. Even a kid could do it. He said ALL electric waters heaters use 220 volts and 30 amps. So I would need 10-3 romex with ground. I told him my neighbor used 10-2. He said everything in America needs to have a neutral wire now days, but that some things don't use it. He said if my water heater didn't have a place for the white wire, I should just connect it to the same screw as the ground.
I asked if I needed a disconnect. He said I didn't need one but if I wanted one I could just put in a "wall switch" and switch the red wire. I asked to see a "wall switch" and he pointed out a standard single pole snap switch for lighting. I asked if that switch would handle the 240 volts because it said 120 on it. He corrected me and said we don't have 240 volts in America only 220 and 120. He went on to tell me the switch would work fine because it would only be on one wire and that wire was 120 volts.
And here is my favorite part, I told him I had two empty spaces in my panel but they were not next to each other. He showed me 2 single pole 30 amp breakers and told me to just put them in the spaces in the panel and put one wire on each. (I always wondered why they sold single pole 30's, now I know). And to put the ground and white in the same hole on that bar thingy in the panel.
I told him I would go find my wife before buying the stuff. I asked how he became a Master Electrician and he told me he had been an electrician in a school for 20 years, and then took a test. I said, you mean like a custodian? He said yes, but he also did all the electrical work. He told me he had to be very careful in that school because everything ran on 480 volts.
Old 04-04-2008, 10:45 PM   #55
I don"t have a link to a site but spoke to my underwritter about this matter U can speak to a underwritter in your neck of the woods or I can get u my underwriters # This concerns the # of breakers in a panel and the ark fault matter.
Old 04-04-2008, 11:19 PM   #56
jOHN
No I don"T have a link , but spoke to my underwriter which I can forword his # to you. But Iam sure you know one.
Old 04-04-2008, 11:27 PM   #57
jrclen's Avatar
Rewards Points: 514
jOHN
Where are you Joe? What's an underwriter?
Old 04-05-2008, 10:02 AM   #58
Rewards Points: 2,350
Oh, silly! He means undertaker!
InPhase277
Glass Fuse Panel box question? pouncerw Electrical 4 10-05-2009 10:01 PM
Multiple Sub Panel Installation Handyman2007 Electrical 26 12-31-2007 06:47 PM
breaker panel question chadvavra Electrical 11 08-10-2007 10:20 AM
Main panel design question amakarevic Electrical 13 06-04-2007 05:35 AM
3 phase panel question curse21 Electrical 2 08-18-2004 11:17 PM
