Question Regarding A Sub-panel - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-09-2008, 09:30 PM   #31
Most Awesome Website
Dale I am soon going to be doing what you are doing.
I found this most awesome site with pics on how to do this. check it out!
http://www.hammerzone.com/archives/e...in_changes.htm
make sure to continue to part #3
Guys feel free to comment.
luweee is offline   Reply With Quote
Old 03-10-2008, 05:41 AM   #32
When is fishing season?
CowboyAndy's Avatar
I have seen this before, okay for the average DIYER wanting to install a sub panel.
One thing I noticed about the article is this.
See the cable below the box? Why would anyone bend the cable that tightly???
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-10-2008, 09:11 AM   #33
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
No one should. Good catch.
jrclen is offline   Reply With Quote
Old 03-10-2008, 09:19 AM   #34
CowboyAndy's Avatar
I was just looking in the code to find the exact defination, but isn't it something like a minimum radius of 5 times the diameter of the wire?
MY HOUSE OWNS ME!
Old 03-10-2008, 11:04 AM   #35
The white cable below the blue box correct?
What are they dooing that for? Seems senseless!
But otherwise, hows it look as far as putting in the subpanel?
The grounding, OR what Dale said "BONDING", is correct for the Main and the "Mainlug"?
Old 03-10-2008, 09:19 PM   #36
Sorry to say I actually thought that it was two wires going though the stud- even I know not to do that.
DaleB is offline   Reply With Quote
Old 03-31-2008, 06:41 PM   #37
Originally Posted by InPhase277 View Post
If you have a 100 A main panel, you might as well upgrade to a 200 A 40 space panel and service... but... just because a breaker is labeled 100 A doesn't mean that it is "pushing" 100 A to the load.
I don't see a problem with it. You can jam as many breakers of any rating into it that will fit.
InPhase277
note in a 100 amp panel u may only have 30 spaces filled
in a 200 amp you may only have 40 spaces filled
joed1234 is offline   Reply With Quote
Old 03-31-2008, 06:45 PM   #38
Rewards Points: 150
Not true ...
it is 20 spaces for a 100a panel, and 30 spaces for a 150a panel.
JGarth is offline   Reply With Quote
Old 03-31-2008, 06:46 PM   #39
InPhase277
check your on how many beakers can be in a panel
Old 03-31-2008, 09:03 PM   #40
simens makes a 100 anp 30 circuit panel alogn with other companys
Old 03-31-2008, 09:05 PM   #41
so you can have 30 breakers in a 100 amp panel to jgarth
Old 03-31-2008, 09:06 PM   #42
Old 04-01-2008, 09:35 PM   #43
jrclen's Avatar
Rewards Points: 514
The 2008 code removes the maximum number of circuits in panels.
Old 04-02-2008, 04:50 AM   #44
CowboyAndy's Avatar
But isn't a panel also listed by the manufacturer regarding how many breakers it can have?
MY HOUSE OWNS ME!
Old 04-02-2008, 07:40 AM   #45
jrclen's Avatar
Rewards Points: 514
Yes they are. But the manufacturers will be free to design panels as they wish. Those panel will still need to be tested and listed by a testing agency such as UL. Only the arbitrary limits will be eliminated. State and local codes may have something to say also.
Glass Fuse Panel box question? pouncerw Electrical 4 10-05-2009 09:01 PM
Multiple Sub Panel Installation Handyman2007 Electrical 26 12-31-2007 05:47 PM
breaker panel question chadvavra Electrical 11 08-10-2007 09:20 AM
Main panel design question amakarevic Electrical 13 06-04-2007 04:35 AM
3 phase panel question curse21 Electrical 2 08-18-2004 10:17 PM
