Question Re Wiring Middle-of-run Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2013, 02:52 PM   #1
Rav
Rewards Points: 542
Question re wiring middle-of-run receptacle
Electrical newbie here, just trying to educate myself. Referring to the following video describing two alternative wiring methods for a middle-of-run receptacle:
Method one describes connecting the incoming hot to one brass screw, and the outgoing hot (to the next receptacle) to the other brass screw. Likewise, the incoming and outgoing neutrals connect to the two silver screws. (Of course, the tabs must be present.). This method is simple; it doesn't require any pigtails or wire nuts.
Method two uses just one each of the brass and silver screws, but uses pigtails and wire nuts. It seems more complex to me and would take (me) more time.
Other than perhaps local code requirements, why would one ever choose method two over method one? Thanks.
Rav is offline   Reply With Quote
Old 08-29-2013, 03:02 PM   #2
CitadelBlue's Avatar
Rewards Points: 97
Can't think of one other than having one hot incoming and two or more outgoing to two or more different outlets and there just isn't enough room to make the three or more wire connection on the outlet...
Ken
Because you NEVER have enough room .........
See my Trailer and Hitch Thread
CitadelBlue is offline   Reply With Quote
The Following User Says Thank You to CitadelBlue For This Useful Post:
Rav (08-29-2013)
Old 08-29-2013, 03:04 PM   #3
Rewards Points: 141
I'll take a stab at it.... No pun intended ... if the pigtailed outlet fails for some reason, the outlets downstream will still work because the electricity has a path to follow (due to the pigtail wiring. I'm guessing that the outlets wired with pigtails are connected in parallel while the other method is in series.
RocketGal is offline   Reply With Quote
The Following 2 Users Say Thank You to RocketGal For This Useful Post:
Kyle_in_rure (08-29-2013), Rav (08-29-2013)
Old 08-29-2013, 03:26 PM   #4
Electrical Enthusiast
Rewards Points: 504
The first two posters are correct. The idea is that If one receptacle fails the others down the line will still work. Also. If you're dealing with more than two cables in a box, it may be easier to pigtail everything together.
It is a matter of preference as far as I know.
Kyle_in_rure is offline   Reply With Quote
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
Rav (08-29-2013)
Old 08-29-2013, 04:28 PM   #5
Oso954's Avatar
Rewards Points: 428
You can make your pigtails up and side wire the receptacle standing up, before bending over or getting down on your knees.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 08-29-2013, 07:16 PM   #6
Rav
Rewards Points: 542
Thanks to everyone for your responses. That's what I love about these forums -- it's great to learn the reasons behind these things from people who are more experienced with them than I am.
Old 08-29-2013, 07:52 PM   #7
Rewards Points: 150
Also if you have a whole string of outlets wired like this, you will have some voltage drop due to resistance in outlets.
romex1220 is offline   Reply With Quote
The Following User Says Thank You to romex1220 For This Useful Post:
Rav (08-29-2013)
Old 08-29-2013, 08:45 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
NOT! Any VD in this case is insignificant.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
jbfan (08-30-2013), Jim Port (08-29-2013)
Old 08-30-2013, 09:15 AM   #9
joed's Avatar
Rewards Points: 11,576
Pig tails just add more unnecessary expense(wire nuts, pigtail).
In Canada wire nuts add to box fill as well, so better make sure your boxes are large enough.
I use the screws always when there are enough of them.
Old 08-30-2013, 09:49 AM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
Pigtails are only required on the neutrals of a MWBC.
Any other time, the screws are good enough.
It comes down to how you were taught to wire receptacles.
The people that taught me always pigtailed,so I have been doing that for 30 years.
120v gas range wiring question Redfishjoe Electrical 5 05-11-2011 10:37 PM
Receptacle and wiring question Abs777 Electrical 6 03-12-2010 09:47 AM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 10:52 PM
Wiring timer from receptacle intotao Electrical 7 01-21-2009 09:57 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
