Question RE: Panel's Legend - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2012, 10:26 PM   #1
Question RE: Panel's legend
Can someone explain what the numbers represent on the legend as highlighted?
For example, on the line side it says 6-2/0.
Is this a range from 6 AWG to 2/0?
On the ground bus it says 14-6, is this a range from 6 AWG to 14 AWG or 6, 14 guage wires?
Question RE: Panel's legend-img_0119a-small-.jpg
marc216 is offline   Reply With Quote
Old 12-11-2012, 10:27 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Yes and yes
Old 12-11-2012, 10:34 PM   #3
Missouri Bound's Avatar
Wow....if only all questions could be answered so simply.
Do you want it your way or the right way?
Old 12-11-2012, 11:21 PM   #4
so if there is a range from 6-14 for conductor size, is there a "maximum" number of conductors allowed under a terminal?
Question RE: Panel's legend-img_0126-small-.jpg
Old 12-11-2012, 11:25 PM   #5
k_buz's Avatar
That triple tap is not legal and neither is that GEC. The armor should be removed and the cable should be terminated with an approved connector.
Old 12-11-2012, 11:33 PM   #6
joed's Avatar
Rewards Points: 11,560
One conductor per terminal.
Old 12-11-2012, 11:49 PM   #7
Rewards Points: 12,818
Anyone else notice the aluminum and coper wires in direct contact under that clamp?
electures (12-12-2012)
Old 12-12-2012, 12:53 AM   #8
Great thanks. Last question; so if the legend says #6-14, then per NEC you are only allowed one (1) conductor per terminal so either a 6,8, 12, or 14 (co) is allowed in that terminal, yes?
Old 12-12-2012, 07:34 AM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
That is correct.
Some panels allow 2 conductors, but only on the ground bar.
That will be listed on the legend also with the other info you have found.
Old 12-12-2012, 10:03 AM   #10
thank you very much.
Old 12-12-2012, 11:16 AM   #11
Rewards Points: 1,192
Been like that for years.Where is the disimmilar metal reaction?
bobelectric is offline   Reply With Quote
Nube with a nube question for non-nubes screamsong Carpentry 15 05-17-2012 09:51 PM
2 Wires coming from 200 AMP Meter to separate panels? shelzmike Electrical 2 02-17-2012 11:02 AM
Decorative Interior Wall panels: question AndrewY Painting 2 05-22-2009 02:16 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
