Question Re GFCI Replacement - Electrical - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 04:29 PM   #1
Question re GFCI Replacement
Hello All:
I have a somewhat (?) unusual question about our favorite friend, the GFCI outlet.
The outlet in my half bath is GFCI and is no longer functional (we use it to blowdry my daughter's hair and it finally gave up the ghost). In any event, I tried determining which subpanel break controls the GFCI in order to swap it out. However, there is no such breaker (there is still current on the hot wires even though I've turned off all the breakers in turn).
Is it possible the GFCI is directly connected to the main load panel breaker? It is an older home (c. 1960s) although the electrical was upgraded at some point before we bought it.
I guess I could shut off the main but I'd like to avoid it at all possible.
Thx.
John
JPShinn is offline   Reply With Quote
Old 01-02-2011, 04:37 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 530
It will not be wired to the main breaker.
How did you detrmine that you still had current on the hot wire?
Old 01-02-2011, 05:01 PM   #3
I pulled the GFCI receptacle from the wall and used a circuit tester on the individual hot wires. I got a 110v light...
Old 01-02-2011, 06:00 PM   #4
the Musigician
DangerMouse's Avatar
You say "sub-panel", sooo, you have another panel? Have you systematically tried those?
DM
Old 01-02-2011, 06:13 PM   #5
DM
Well, the main panel is in effect my main load breaker where the drop from PG&E. It is one of those Frankenstein-like devices. Closed and the house has power but lift it up and no power to the house. The subpanel is in the garage on the other side of the house.
Thx
John
Old 01-02-2011, 06:30 PM   #6
the Musigician
If following code, it should be a 20 amp circuit.
You may HAVE to shut down the main and use a flashlight and do it.
DM
Old 01-02-2011, 06:58 PM   #7
Did you shut power off to the sub & then test for power ?
Old 01-02-2011, 10:13 PM   #8
I don't believe there is a way to shut off the power to the subpanel independent of shutting down the whole house.
Again, it is probably something I'll have to do but it also strikes me as being a stupid wiring set up to begin (gotta love dated wiring + somebody's patch upgrade some time ago).
Thx.
John
Old 01-02-2011, 10:19 PM   #9
Ah.....every sub I run has a main circuit breaker
I do like being able to shut off power at the sub all at once
Old 01-02-2011, 10:56 PM   #10
Yes, I don't doubt that. However, it is non-existent in my setup (at least from a basic eyes-on perspective)...
Thx.
John
Old 01-03-2011, 12:17 PM   #11
Scared Electrician
Saturday Cowboy's Avatar
sounds like somebody got two circuit tied together. so the trick is to figure out which two breakers power the plug.
Saturday Cowboy is offline   Reply With Quote
Old 01-03-2011, 12:34 PM   #12
Sounds like I need to bring a proper electrician out to the house...
GFCI Question Steve in CT Electrical 8 12-07-2010 03:29 PM
replacement window question hitmehhh Building & Construction 16 11-23-2010 07:33 PM
Siding replacement question MeatballCB General DIY Discussions 16 02-05-2010 02:53 PM
GFCI question. Please Help. the banana k1ng Electrical 4 10-09-2009 07:35 PM
Hot Tub GFCI Grounding Question kearnak1420 Electrical 3 04-30-2008 05:48 PM
