Old 02-05-2009, 10:37 PM   #1
Question on QO-20M Square D panel
I was wondering if there are any limitations on where I can place double pole breakers in this QO-20M panel? (other that the fact that they need to be on seperate phases).
rovers1973 is offline   Reply With Quote
Old 02-05-2009, 10:48 PM   #2
Electrical Contractor
Nope!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 02-05-2009, 11:01 PM   #3
Thanks.
I was also wondering if I should add a ground bar to this panel? I am putting in a sub panel to get rid of a bunch of the tandems that are in now and I notice that all the ground wires go to screw connections in the case itself? (and there are only 4 of them)
Old 02-05-2009, 11:23 PM   #4
Add the ground bar kit. You will need it later.
Old 02-06-2009, 05:14 PM   #5
Are the ground bar kits specific to each panel, or just to the manufacturer?
Old 02-06-2009, 05:47 PM   #6
A ground bar is a ground bar but the mounting holes/screws are panel specific.
Technically you can't use self tapping screws....unless they are self tapping machine screws.
Self tap it if necessary and don't lose any sleep over it.
220/221 is offline   Reply With Quote
Old 02-06-2009, 09:07 PM   #7
Great, thanks for the help everyone.
Tags
qo-20m. panel, square d
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
main breaker panel terminology question! jeffjohnson1 Electrical 3 09-30-2008 09:04 AM
Next Question, Sub panel in detached garage... OmegaBunny Electrical 5 09-16-2008 12:37 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
3 phase panel question curse21 Electrical 2 08-18-2004 11:17 PM
