Question On Putting An Outlet Under The Sink - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 07:08 PM   #1
Question on putting an outlet under the sink
I'm adding an airswitch for my new disposal. The previous disposal was lid-activated and wired directly into the disposal.
My new disposal has a plug and I need to add a GFCI outlet under the sink. The wiring that comes from the floor into the base cabinet under the sink is flexible armored cable (BX). I want to mount the outlet/box on the back of the base cabinet (that is, I do not want it to be recessed). What type of box should I use? Any other suggestions?
Thanks!
svidrillion is offline   Reply With Quote
Old 02-24-2012, 07:36 PM   #2
Master Electrician
Rewards Points: 3,916
Use a handy box. No GFCI required.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
svidrillion (02-24-2012)
Old 02-24-2012, 08:25 PM   #3
Is that all that's required? I was worried about moisture getting into a metal box.
Old 02-24-2012, 08:42 PM   #4
Licensed electrician
Rewards Points: 1,744
It should not be wet under the sink.
Old 02-25-2012, 01:28 AM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,970
GFCI is not required, but also not a bad idea.
mpoulton is offline   Reply With Quote
Old 02-25-2012, 06:30 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
I'll reiterate, WHY would there be moisture UNDER the sink???
A GFI is NOT required, and IMO is not needed.
I would use a 4" square box with a raised finished cover. We call them "industrial" covers. The on in Brric's picture is way to small to do anything with, especially if you are set on using a GFI.
Old 02-25-2012, 07:37 AM   #7
There isn't any moisture under the sink right now, but I was just thinking about what if the sink starts to leak or something--wouldn't I want a GFI there?
Can I put a 3-prong outlet (non-GFI) to attach to the BX cable?
Thanks!
Old 02-25-2012, 08:26 AM   #8
Rewards Points: 160
If you're worried, buy an outdoor rated box for a few dollars more.
matt151617 is offline   Reply With Quote
Old 02-25-2012, 09:33 AM   #9
Master Electrician
It was just an illustration. I wouldn't use a 13 cu inch box either. Deeper handy boxes are available.
Speedy Petey (02-25-2012)
Old 02-25-2012, 12:20 PM   #10
Of all the places in a house that aren't supposed to be wet, the cabinet under a sink seems to be the one that gets wet most often for me. Drains and disposals leak, shutoffs leak, countertop spills run down through cracks, dishwasher drain hoses leak, etc. And when it does get wet under there for some reason, it often requires that someone work down there while it's wet. I hate being under a wet, leaking sink to fix it - even more so when my face is next to a wet receptacle and garbage disposal. I've done that a couple times. A GFCI there would give some peace of mind. Also, the metal garbage disposal chassis is directly connected to the metal drain ring in the sink. The grounding conductor SHOULD provide adequate protection, but it doesn't hurt to have a backup. As the guy who both works on sinks and changes receptacles in my rentals, I've put in GFCIs whenever I've replaced a receptacle under a sink unless it's a switched split for the dishwasher and disposal.
Old 02-25-2012, 12:28 PM   #11
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would also use a box that can't easily get any water in it.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-25-2012, 05:19 PM   #12
This is the reason why I thought of using the GFI. Thanks for the help, folks. I ended up putting a GFI in a 4-in deep handy box with a plastic cover because I couldn't find any of the metal ones that fit a GFI. Then I plugged the airswitch and disposal in and everything is working.
Old 02-25-2012, 06:04 PM   #13
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Thats the box and cover Id use also,by the time you stuff wires and a plug in one of those handy boxes theres really no working room.
As far as the gfi goes just the fact that its under a sink surounded by plumbing seems like a good reason to use a gfi to me,anybody whos ever been stuck on their back halfway under a cabinet trying to run a snake down through a ratty old san-tee will tell you about moisture under a sink!
And if moisture is the only reason to install a gfi why do all the other areas of the kitchen that arent around water require them?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-26-2012, 10:31 AM   #14
Rewards Points: 240
You did use clamps to bring the wiring into the box, right?
fa_f3_20 is offline   Reply With Quote
Outlet spacing in new renovation question Little Electrical 2 12-28-2011 06:32 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
bathroom sink stopper question - Pictures in thread amodoko Plumbing 5 05-31-2011 05:24 PM
Utility Sink Plumbing Question justinL Plumbing 2 08-16-2010 08:10 PM
2ft Wall/Hallway Electrical Outlet Question?? hatchekc Electrical 1 07-17-2010 08:51 PM
