Question On Making Own Gen Cord - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2012, 07:52 AM   #1
question on making own gen cord
Is there a trick or tip to tighten the plug clamp around the cable sheathing to prevent water penetration?
My Leviton 30 amp male plug (as well as Cooper 30 amp female plug) would not clamp down all the way when using the #10 patch cord, leaving small gaps around (not sure the exact term, but it is rated for outdoor use and is flexible - stranded copper in black, red, white and ground wires).
Copper did provide four, small plastic clips but the instruction did not clearly explain what and how they were supposed to be used.
According to their instructions, both plugs are rated to be used up to #8 outdoor cable.
Due to having no power, I reluctantly used duct tape to seal the gaps but would like a correct solution.
thanks in advance.
allthumbsdiy is offline   Reply With Quote
Old 11-02-2012, 08:17 AM   #2
joed's Avatar
Rewards Points: 12,918
Is it a a waterproof plug similar to this one with the rubber seals?
Old 11-02-2012, 10:42 AM   #3
Rewards Points: 160
You will never get the clamp all the way down with a 10/3 cable. That is how it works. Duct tape is silly and not needed.
Your generator inlet is designed to keep the cable end dry and most decent generator manufacturers have a roof or plate over the receptacles.
Running an extension cord through pvc s10sleeper Electrical 6 08-12-2012 12:15 AM
Replacing 2-wire cord on old motor Arnold Ziffel Electrical 4 03-13-2012 11:52 PM
14/3 Power Cord in conduit NotSoElectric Electrical 10 09-05-2011 09:40 AM
Adding my own GFCI into an extension cord question???? stanlam Electrical 5 07-15-2011 07:38 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
