Question On Grounding Main Lug Service - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 05:32 PM   #16
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Originally Posted by rjniles View Post
I respectfully disagree
That's perfectly ok, it's what good about a forum.
wirenut1110 is offline   Reply With Quote
Old 06-19-2012, 06:50 PM   #17
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
But we all know the AC equipment never ends up on right next to the electrical equipment....or anything else convenient for that matter.
Old 06-19-2012, 07:02 PM   #18
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Damn architects
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 06-19-2012, 07:11 PM   #19
E2 Electrician
Damn architects
LOL... To share what I generally see in the field, pedestal style meter way out in left field, AC equipment other side of house, remotely located... I end up installing a sub panel at that location. To be honest, I don't even think I could use a meter like pictured, its just uncommon in this area. I don't think one of that nature is on the list of accepted meters.
Old 06-19-2012, 07:24 PM   #20
A "Handy Husband"
rjniles's Avatar
New construction in this area very often uses meter main panels (I think all the main electrical equiment manufacturers make them - GE, Square D, Siemens, Eaton. And surprisingly, often I see the AC compressor on the same side of the building. Who woulda thunk it
Old 06-19-2012, 07:56 PM   #21
E2 Electrician
I agree with you, BUT... out here, it just doesn't exist... Just different areas, different ways... not wrong either way, just different. To put this in a different light, in the 18 years of being an electrician, I have never seen a branch circuit installed off a meter enclosure... Which these forums offer these kinds of benefits.
Old 06-21-2012, 04:03 PM   #22
Sorry I havent responded I've been digging the conduit and pulling the wire the last few days. I ran 4/0 4/0 4/0 2/0 in 2" schedule 80. Sucked.
Now I talked to the inspector and he wants a ground above and below my water meter in the basement and 2 ground rods. So Ill run #4 continuously from the 2 clamps back to the main lug and then where does it go from there? There are 2 lugs for the hots and then what looks like a neutral/ground bar on the left with a lug on the bottom and a lug in the middle. Am i right to assume neutral goes to the bottom lug and ground goes to the center? Grounding rods go to a space on the neutral/ground bar and water main goes to another?
I could take a picture of it or draw it up to clarify, Im sure that Im confusing people with my lack of terminology.
rizzoa13 is offline   Reply With Quote
Old 06-21-2012, 04:18 PM   #23
I busted out some amazing paint skills to clarify my question. Enjoy, it took me forever.
Old 06-21-2012, 08:15 PM   #24
joed's Avatar
Rewards Points: 11,964
The neutral and the ground must be kept separate. Two separate bars are needed.
Old 06-21-2012, 08:35 PM   #25
Even in the main disconnect? I know the panel has to be separated but do I need to get a separate ground bar for the main disconnect also? This is a main lug setup out that helps.
Old 06-21-2012, 11:39 PM   #26
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I used 4/0-4/0-2/0-#2 for my 200 amp sub panel and needed 2-1/2" to pass for conduit fill. Did the inspector say that you would be ok with 2"?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 06-22-2012, 12:59 AM   #27
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I think Joe thought you were showing the sub-panel.
The main disconnect is more properly referred to as your 'Service Equipment' for grounding purposes. Neutral and ground always bond at that point in the system.
Your drawing looks fine to me. Only thing I can add is that if the conduit from meter to your disconnect is metal you will need a bonding bushing screwed to the conduit and bonding jumper from that to the neutral bar in the discoinnect.
Old 06-22-2012, 01:16 AM   #28
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Looks like that is OK...my code book says 4 4/0 XHHW in a 2" SCH 80 PVC.
Old 06-22-2012, 06:15 AM   #29
From the meter to the disconnect I was planning on running SE cable, is that acceptable? That will be the last thing I do once the power is turned off.
2" was very tight for the 4 wires to be run through especially as my first time pulling wire. Id have gone bigger if I knew how hard it would be. Are there any regulations on running the conduit underground other than depth? Such as a distance from other services because mine runs very near my gas line.
Old 06-22-2012, 08:51 AM   #30
joed's Avatar
Not in the main disconnect. There they should be connected. I thought we were discussing the main panel in the house.
Grounding question for subpanel mn1247 Electrical 26 09-19-2011 11:41 AM
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 09:15 PM
grounding electrode conductor question bsperr Electrical 8 12-05-2009 10:23 AM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 05:34 PM
Hot Tub GFCI Grounding Question kearnak1420 Electrical 3 04-30-2008 06:48 PM
