Question On Generator Wiring - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-10-2007, 12:06 PM   #31
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Yeah... I knew you were just posting to inform Mdalli of interlocks as an option. You weren't pushing that particular interlock. Actually if you can't find a cheaper one it still is a little pricey but so are transfer switches. I guess we upset him by our advice. He is going to get a surprise though when he realizes he likely is going to lose 2 or 3 breaker spaces to get one installed that will work correctly. I'm sure if you have the machine tools and are a good enough craftsman it could be done. But it ain't something I would risk.
Having dealt with a few lawsuits in my day the insurance is required by law to make payment regardless of your stupidity. If it was made by a hired electrician and no inspection then they may file suit for a recovery of costs against the electrician. Generally if the legal pursuit is more costly than paying the claim they just pay and be done with it.
Stubbie
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 11-25-2007, 04:57 PM   #32
Unhappy
pros and cons of natural gas generator
My basement got flooded because the battery for sump pump run out of power. I was told that natural gas generator with automatic switch box is the way to go to power the sump pump when I have power outage again. Only thing I know is it costs a lot. Things I have not idea are: is the natural gas generator reliable? What are the better models? Does it need heavy and expensve maintainance? Other than you need to have enough gasaline and personally start the generator, any other down side of gasaline generators relative to natural gas generator?
lacuna is offline   Reply With Quote
Old 10-05-2011, 08:03 AM   #33
Interlocks for less than $150?
It's been several years since the above posts were made suggesting that there are interlocks more reasonably priced than those by InterlockKit, but I just joined this forum yesterday. I looked, but couldn't find any companies that make one for my load center. Even the one that InterlockKit suggested I buy isn't right for me because there's a 1/4" difference in the specified dimensions of my panel and what they say it was designed for. So if I were to buy it, that difference might mean I would have to modify it somewhat. That doesn't seem like a big deal to me, but if that does turn out to be the case, the thought came to me that I might as well just make the device myself. I know I'm capable of doing that but would prefer to just buy one. But I had no luck searching for alternate suppliers. NoOutage is one, but it is just a reseller of the InterlockKit brand, so that was no help.
My 45-year-old load center was made by GE, but they couldn't help either. Can anyone provide a list of interlock manufacturers.
LarryF is offline   Reply With Quote
Old 10-05-2011, 08:14 AM   #34
Code05's Avatar
Rewards Points: 1,104
Start a new thread, you will get better results.
Code05 is offline   Reply With Quote
Old 10-05-2011, 05:46 PM   #35
dmxtothemax's Avatar
Rewards Points: 5,190
Originally Posted by mdalli View Post
Just purchased a generator, and my thoughts turn to a transfer switch, but I have a question.
Every transfer switch I've seen basically duplicates the existing breaker box and has no mechanism to ensure you kill the utility main (so you don't backfeed the utility w/ your generator).
My question is this: wouldn't it be much, much simpler to install a 3PDT switch directly upstream of the main breakers on your house?? This would ensure that you could either have the generator powering your house or the utility, but never both. It would also use the existing breakers in your breaker box. What am I missing here??
I think you have the wrong idea !
If a transfer switch is properly installed,
Then it does indeed,
isolate the incoming mains,
and prevent back feeding,
this is the main reason for transfer switchs!
Perhaps you are thinking about manual interlocks,
But even manual interlocks should prevnt back feeding
if installed correctily.
dmxtothemax is offline   Reply With Quote
Old 10-05-2011, 07:45 PM   #36
Missouri Bound's Avatar
Lacuna. You would be wise to start your own thread, since this one is 4 years old. And there are several generators out there that you could have for around $3000 installed, if you shop around.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
