Question On Conduit For Exposed Wiring In Finished Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 03:14 PM   #1
Rewards Points: 95
Question on conduit for exposed wiring in finished garage
I adding an outlet in my finished garage. I don't wan't to cut into the drywall and drill through studs, so I plan to come off an existing outlet and run about 3ft of EMT to the new outlet. I can use Red Dot box extension on the old outlet, then the conduit, then a 1-gang box for the new outlet. The length of the conduit will be 33 inches. Do I need to fasten the conduit to the wall, or is the conduit considered supported on the to ends by the boxes?
garya505 is offline   Reply With Quote
Old 12-27-2011, 03:16 PM   #2
Rewards Points: 6,652
I would if you can. You never know, regardless of the length.
Old 12-27-2011, 03:31 PM   #3
Rewards Points: 95
Ya, I'm just trying to avoid extra work an expense.
I usually do overkill on everything, but would like to kick that habit.
Old 12-27-2011, 03:33 PM   #4
Julius793's Avatar
NEC doesn't require it if it's less than 3'. However I sometimes will
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
The Following User Says Thank You to Julius793 For This Useful Post:
garya505 (12-29-2011)
Old 12-27-2011, 03:39 PM   #5
Electrician
Rewards Points: 802
I'm not familiar with the red dot products(probably an American product).
In your situation I would use an 1110 extension, may be referred to as a handybox in your area. Here is a picture of a handybox, the extension would have no back on, just two holes to screw to your existing box. http://www.homedepot.com/Electrical-...atalogId=10053
I would also recommend trying to get it clipped to the wall, you should be able to get back to back off sets in a 33" piece of 1/2". Put one clip in the middle of the two boxes, and it shouldn't go anywhere.
darren is offline   Reply With Quote
Old 12-27-2011, 04:30 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Use wiremold for a better look.
Old 12-27-2011, 05:34 PM   #7
It would be just one conduit strap to secure in the middle. A lot of work, is going back and repairing it, when one of the kids decides to hang off of it, or such.
Old 12-27-2011, 06:25 PM   #8
Rewards Points: 1,766
"Ya, I'm just trying to avoid extra work an expense"
1 conduit clamp midspan might take 2 minutes and $0.50.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
gregzoll (12-27-2011)
Old 12-27-2011, 06:37 PM   #9
Rewards Points: 95
You need to offset the EMT to clamp it properly. Getting good bends on a piece that short is tricky for a DIYer. Or you can buy the offset adapters.
Old 12-27-2011, 06:41 PM   #10
Rewards Points: 95
I considered that, but the 1-gane boxes are only 11.9 cubic inches and too small for the number of wires I have.
I might try to use this:
http://www.homedepot.com/h_d1/N-5yc1...1&ddkey=Search
and this:
Old 12-27-2011, 07:00 PM   #11
jbfan's Avatar
Rewards Points: 650
and this:
A lot of money to move a receptacle 33 inches.
Just use a power strip.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
darren (12-27-2011), gregzoll (12-27-2011)
Old 12-27-2011, 07:07 PM   #12
That is what I did in my garage jbfan for the xmradio & shelf system that we use to listen to it with. Instead of pulling another outlet, power strip did wonders. Of course if they still want to do it, there are other boxes out there like the PVC ones.
Old 12-28-2011, 01:58 AM   #13
Rewards Points: 95
I need another outlet there because of some HVAC equipment.
I found some deeper 1-gang Wiremold boxes that will work, so I'm going that route. The first ones I saw were too small, but the deep ones will work fine and they're about $6 each at HD.
Old 12-28-2011, 06:50 AM   #14
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
I hate single gang/handy boxes myself,by the time you get a connector on there and a plug its pretty well stuffed
I prefer 4sq boxes and a plaster ring or a metal surface mount cover,lot more room inside box to work with.
Just say no to those pre made offsets,borrow a bender and throw a box offset in each end an a 1 hole strap in the middle of it!
plummen is offline   Reply With Quote
Old 12-28-2011, 09:22 AM   #15
JOATMON
ddawg16's Avatar
Rewards Points: 2,116
Personally.....I would cut the drywall and drill the studs. Then, your only cost is the wire, box and a little bit of mud.....
Yea, it's a little more work....but patching drywall is actually real easy.....I find the biggest obstical is getting started.....
The Following User Says Thank You to ddawg16 For This Useful Post:
Garage Wiring VinceA Electrical 14 09-11-2010 08:05 PM
garage / bedroom wiring code question 205bhamjim Electrical 4 01-20-2010 09:55 AM
Conduit tubes for Structure Wiring Codes genner Electrical 7 05-29-2009 02:39 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
Two Family Duplex - Garage Wiring Question Moonlight24 Electrical 2 06-22-2008 10:31 AM
