Question On AFIC - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2011, 05:36 PM   #1
Question on AFIC
Are these two AFICís the same? They seem to be the same except for the description in the package and the test buttons. Both are made by the same company and both seem to detect parallel arcing faults. I was thinking that maybe the one of the left is just an early version. Can I use both in my box as an AFIC and be within code?
Thinks in Advance,
I see the tag inside reads as follows:
TEST BUTTONS
Green - Circuit Breaker and Branch / Feeder Arc-Fault Circuit Interrupter.
White - Circuit Breaker and combination Arc Fault Circuit Interrupter.
Yellow Ė Circuit Breaker and Ground Fault Circuit Interrupter.
John3rd is offline   Reply With Quote
Old 10-11-2011, 05:42 PM   #2
Licensed electrician
Rewards Points: 1,766
The latest edition of the code requires the combination AFCI. Earlier editions just required AFCI.
John3rd (10-11-2011)
Old 10-11-2011, 05:59 PM   #3
Thanks Jim, That's what I was reading. I have the newer ones in the house. I really didn't need these but figured I'll use them in her craft room along with the GFI's Then again, I seem to do an overkill when it comes to elect and the wife. She does a lot of stained glass and always cutting glass or grinding glass in water.
Old 10-11-2011, 06:06 PM   #4
Electrical Contractor
kbsparky's Avatar
For any lurkers out there, if you encounter a BLUE test button on any Square D Arc-fault breaker, those are the really O-L-D ones, some of which were recalled!
-KB
The Following 2 Users Say Thank You to kbsparky For This Useful Post:
gregzoll (10-11-2011), John3rd (10-11-2011)
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
